Max path depth
3 posts • Page 1 of 1
mhouki
Max path depth
Post by mhouki » Wed Jul 24, 2019 5:24 am
Hello Everybody!
I'm trying to render a short animation using GPU. Since they're quite a lot specular materials existing in the scene it requires slightly higher than 8 max path depth - 32 in that case :wink: . Is it possible to override it somehow in render queue tab or alter it before export?
I'm using Blendigo.
Cheers!
yonosoy
Re: Max path depth
Post by yonosoy » Mon Jul 29, 2019 8:36 am
Hi mhouki.
You can try to write this line in the inifile.xml that is in Indigo´s directory.
<gpu_max_depth>32</gpu_max_depth>
Re: Max path depth
Post by OnoSendai » Tue Jul 30, 2019 7:50 am
It's not possible to set in the queue overrides currently, but have added it for the next release.
