by lycium » Wed Jun 15, 2011 6:32 am
The ideal thing is a relatively inexpensive Quadro (for the optimised drivers) AND a dedicated GTX 570 for GPU computation.
This has added benefits:
* Doesn't mess with your screen refresh rate while rendering
* No timeout / "watchdog" timer for long running kernels
* All memory is available for CUDA / OpenCL
Stick it on a Z68 motherboard with a 4ghz i7 2600k and you're doing very well
joeyslucky22
by joeyslucky22 » Wed Jun 15, 2011 7:44 am
Will a Quadro FX 1800 suffice?
Here's what I'm looking at for 2 slave computers ATM:
http://amzn.com/w/2RB27DDIH4PK8
I'm not really too concerned about the rackmounts (I work for a data center management company so I'm sure we've got some lying around). I've never done water cooling before but I suppose that's the best way to cool an overclocked i7 2600k at 4ghz?
Does hard drive size on a slave matter all that much? I'm assuming 160GB is enough? And will a 600w power supply do the trick?
SketchUp 8 || Windows 7 Home Premium x64 || CPU: i7-2600k @ 3.4 GHz || 16 GB DDR3 || GPU: GTX 570 1280MB
by lycium » Wed Jun 15, 2011 7:58 am
I would suggest:
1. Just getting a big air cooler instead of the water cooler.
2. Not using Corsair memory, I have personally had bad experiences with their memory with i7 CPUs and so have other users on this forum.
3. 600W might be a little underpowered for an overclocked i7 and a GTX 570.
joeyslucky22
by joeyslucky22 » Wed Jun 15, 2011 8:22 am
Thanks for the help lycium!
Would you go
G.Skill?
This cooler says it's for 1156 cpu's but the 2600k is a 1155. I haven't PC shopped in a long while, does that matter
Would a
700w be enough or should I go
800w to be safe?
by lycium » Thu Jun 16, 2011 1:43 am
G.Skill should be fine, 700W is fine (as long as it's a good one), double check on the heatsink
joeyslucky22
by joeyslucky22 » Thu Jun 16, 2011 3:48 am
Heatsink is A-Ok! Checked Cooler Master's site and it's compatible with the 1155 socket.
One final question (for anyone really) Would I notice any kind of performance increase with a Solid State Drive opposed to just a HDD? I've never owned one but I've heard of their uber speed. I'm guessing I would on my workstation but as slave computers, would the price be worth it? There's a
30GB SSD that's about $80. How much hard drive space do I need for a node server?
joeyslucky22 on Thu Jun 16, 2011 4:10 am, edited 1 time in total.
by Zom-B » Thu Jun 16, 2011 3:56 am
joeyslucky22 wrote:Would I notice any kind of performance increase with an Solid State Drive opposed to just a HDD?
In Indigo not really, but if you install your OS on it or move cache files there you'll notice faster startup times, quicker loading and more fluid workflow but
no faster rendering.
dcm
by dcm » Fri Jun 17, 2011 1:04 am
dont buy i5...
i7 2600k + 16 (or 24) gb ram + 1-2 TB HDD + ati 570/580 and you are fine
believe me
snorky
by snorky » Fri Jun 17, 2011 2:12 am
Coen Naninck wrote:My budget is around 1200 Euros
dcm wrote:dont buy i5...
believe me
tell me where you buy it at this price! x2 for me!
