How to make Indigo to use 80% of CPU ?
10 posts • Page 1 of 1
motorsep
Post by motorsep » Sat Feb 03, 2007 5:20 pm
If I render with Indigo 0.6 or 0.7, my PC turns of becuase of overheating I guess. So I was thinking if I can make it use less CPU, maybe CPU wouldn't overheat. Is it possible?
jurasek
Post by jurasek » Sat Feb 03, 2007 11:55 pm
Under windows search for something like this:
http://www.donationcoder.com/Software/M ... index.html
greetz,
jur
PS. maybe time to vacuum CPU? :wink:
Post by CTZn » Sun Feb 04, 2007 7:08 am
Hey motorsep,
Earlier this day I've been searching for such apps in Sourceforge.net, and everything I found was for Linux, a few for OSX however, and none for Windows. Now I've searched again on the www and found this one, wich I haven't tested tho:
ThreadMaster
It is supposed to CLAMP cpu usage, so that's what you need I guess. Lowering process priority won't avoid the maximum usage of the cpu, while this one is supposed to have success here.
Cheers
zsouthboy
Post by zsouthboy » Sun Feb 04, 2007 9:43 am
Dude, if you have problems with your computer overheating, fix THAT.
Do you have a good heatsink on your CPU? Is the fan still spinning? Is there adequate cooling AROUND your computer (not stuck behind a bookcase or something, is it?)?
motorsep
Post by motorsep » Sun Feb 04, 2007 2:48 pm
I have no problem with overheating if I render with Povray, Blender's Internal renderer. But I have that problem with Indigo :(
Post by CTZn » Sun Feb 04, 2007 6:23 pm
Where is the logic about that ? Renders are shorter ?
boweeb007
Post by boweeb007 » Tue Feb 06, 2007 1:52 am
How do you know that the issue is heat? With the subject of overheating we have the luxury of being objective. This website answers some basic questions and provides a chart of cpu max temperatures:
http://www.heatsink-guide.com/content.p ... temp.shtml
Here are some links to apps that monitor your cpu temp:
http://www.almico.com/speedfan.php
http://www.lavalys.com/
Keep in mind, though, that on-board sensors aren't very accurate. Whatever the software says probably shouldn't come within 6 or 7 degrees celcius of the posted max. Zsouthboy's suggestions are a good place to start if heat really is the issue. Is your system over-clocked?
motorsep
Post by motorsep » Tue Feb 06, 2007 3:56 am
My CPU is not overclocked. And I don't think I have any sensors, because I have old Dell system Dimension 4300S (P4 1.4 GHz)
I can't tell for sure if it's overheating. But since system shuts down on render, I assume it is.
It happens only if I render with Indigo. And shut down happens maximum 1 hr after render has been started.
manitwo
Post by manitwo » Tue Feb 06, 2007 4:12 am
had the same prob with my laptop. what i did?
got a screwdriver - took the laptop apart - searched for the ventilation-system
- took out - went downstairs to my air-compressor - blew the hell (and dust)
out of it - laptop reassembled - wonder where the remaining screws came from
:lol:
boweeb007
Post by boweeb007 » Tue Feb 06, 2007 5:16 am
So often the case!
Seriously, though - an old Dell is probably caked with dust. Good idea, manitwo. Also, make sure you get it out from in between any heat sink fins you can find - not just cpu but northbridge, gpu, ps, etc.
