My Quad Core Machine And Coooooooling! :)
- Kosmokrator
EXACTLY...Kram1032...with this cooling system i minimize the risk of overhead....and i dont have overvoltage the cpu....only the multiplier
and the 3,2ghz is not too much....some people have reack the quad to 4.2ghz!
but i never try this frequencies
Lord of the Rings Junkie
Psh, quad core. You're such a noob.
You need to get yourself one of these: OCTUPLE CORE MAC PRO
*says the man with a single core CPU*...
- joegiampaoli
Overclocking will for sure increase temperatures that's why he has a water cooling system, so it's really not much of a risk as long as you keep an eye on that temperature. Silicon melts I believe at 90°C, processors are made out of that. Still 90°C is quite a high temp, manufacturers tell you 70°C is a risk, but I believe you can still go a little up above that before causing physicall damage or or taking away processor life. They say you can decrease like 50 years of life above 70°C, I would like to see someone save their PC 50 years from now and keep rendering with indigo......
mrCarnivore
- joegiampaoli
mrCarnivore
- joegiampaoli
mrCarnivore
Nope. It's quite cold here. 10 °C is a common outside temp. Highest it goes is about 30 °C in summer, but this is rare (I live in Estonia..it's next to Russia and Finland is over the see).joegiampaoli wrote:suvakas
52°C for idle time is quite high, that's pretty much what mine was at when I lived in Yucatan Peninsula (Caribbean Weather), the ambient temperature there was aprox. 42~45°C, is it that hot where you live? If not, I'd do a checkup on that PC beforeBOOM
I think the main reason why it is so hot is because my box is very small. Everything is side by side. 400w power supply is right next to cpu cooler and 3 hdd's are right there too. I've hade tons of reboots while rendering with Indigo. I gues it runs quite near the edge. The time has come to get a 21 century worstation i guess
A board wich sockets will be out of date soonsuvakas wrote:Anyone knows what's the good motherboard for Core 2 Quad ?
Different cores can stand different temperatures before melting or dying, ranging from 60+°C up to 102°C or so... quickly found that table, found another one few months ago wich was more accurate, and longer also...
