My Car Crash
- Dacksoldier
My Car Crash
this happened last Sunday
I was speeding around my area in my car and i was going down a hill with another road at the bottom which there was a curve connecting the other toad and in the median area was just gravel
I was going about 70 mph when i turned onto the curve and lost traction and slid sideways thru the gravel and when i hit the road it bent my rear tire under the car and it ground out a gash across the road and then the car did a 180 + flipped and landed on the drivers side facing the opposite way and then continued rolling into the ditch and ended up on the passenger side.
I walked out of the car unhurt and my passenger wasn't hurt either. I had owned this car for only 2 weeks about. The car was a 1999 Saab 9-3 SE
- After
- 101_1661.JPG (1.29 MiB) Viewed 17370 times
- Before and Me
- l_4be513e703f21329f1b6726c57faa591.jpg (78.47 KiB) Viewed 17370 times
- front end
- 101_1662.JPG (1.32 MiB) Viewed 17370 times
- The path of the car into the ditch
- 101_1676.JPG (1.31 MiB) Viewed 17370 times
- Look at the rear tires
- 101_1669.JPG (1.22 MiB) Viewed 17369 times
- the long gash in the road
- 101_1685.JPG (1.47 MiB) Viewed 17369 times
- Dacksoldier
- deltaepsylon
- Dacksoldier
Dont "wish" to be more responsible, just be! Think about that: You risked your life for one of the most volatile things, speed. You are lucky that your not in a wheel-chair, paralysed under the neck and wanting to end your suffering by taking your life, but cant because you cant even lift a finger. How miserable is that?
Of course thats a worse case scenario, but it happens all the time.
Good luck with finding a new car and affordable insurance lol
