IQ [1100% non indigo]
- deltaepsylon
Take the test here: http://web.tickle.com/tests/uiq/index_main.jsp and post your results
and what IQ does it spit out?
I got a 127 at approx. 2 am after 3 mugs of cofee, and im 14.
Anyone else?
Anyone else?
- deltaepsylon
very amusing, all online IQ tests are hardly acurate, but this one flaunted it by giving you two (i got 127, if you click the sample report it gives you a diffrent one, in my case 91).
My real IQ is 144, (had to take it and another test to prove i have a learning difference)
Yes i know, my spelling sucks
what kind of learning difference?
Btw: in the last few (10, about) years, the mid IQ of human increased dramatically:
That Quotient was setup to have a mid value of 100. (everything beyond 90 = absolute dump)
but the mid level increases - it now is (children - YOUNG children) at (approx to their age) ~160!
The sample report was just to show you what type of information you would receive should you purchase the full report and is the report of someone else's test. The "91" was the percentage of answers that the subject of the sample test got correct.eman7613 wrote:very amusing, all online IQ tests are hardly acurate, but this one flaunted it by giving you two (i got 127, if you click the sample report it gives you a diffrent one, in my case 91).
so, here we go
I redid the test.
The whole thing:
I'll short down the rest:
I redid the test.
The whole thing:
133 You scored 133 on Tickle's IQ test. This means that based on your answers, your IQ score is between 123 and 133. Most people's IQs are between 70 and 130.
In fact, 95% of all people have IQs within that range. 68% of people score between 80 and 120. The following chart to your right, shows these percentages and where your IQ score is on that scale.
Print your Certificate of Intellectual Achievement.
There's more to intelligence than a single number, a single score or a single label. Tickle uses four distinguishable Intelligence Scales in the Ultimate IQ Test. By analyzing your individual scores on those four scales, we are able to look beyond the raw IQ score into how you process information and thereby determine your Intellectual Type.
Your Intellectual Type Is:
You have a strong ability to process visual-spatial and mathematical information. These skills combined with your strengths in logic are what make you a Visual Mathematician.
You're able to understand patterns visually and in numbers. That means your mind can create a mental picture for any problem. In addition to that skill, you possess an intelligence that allows you to apply math to that picture, too. That helps you manipulate multiple parts of the picture (or problem) to come up with a solution.
You have many skills that are critical to success and problem-solving. Your talents help you understand the "big picture," which is partly why people may turn to you for direction — especially in the workplace. You flourish in environments where tasks are clearly defined, and you are a whiz at improving processes and making things more efficient. Your ability to detect patterns and your skills in math and logic, make it natural for you to come up with ideas and theories that simplify processes for everyone.
Outside of work, Visual Mathematicians tend to do well at strategic activities like chess. It must be that ability to recognize patterns — both as they are and how they develop. Regardless of how you put your mind to use, you've got a great set of talents. You will be able to envision a clear path and calculate the risks, and more importantly, the rewards, of anything you take on.I'll short down the rest:
Mathematical Intelligence 90-100%Code: Select all
Visual-Spatial Intelligence 90-100%Code: Select all
Linguistic Intelligence 70-80% (There are weirdish English questions with that.)Code: Select all
Logical Intelligence 90-100%
- deltaepsylon
I have 127, but an other test (not online) told me I had 133, so its ok.
But some questions are a bit strange. Didn't really understand them, or it wasn't logical for me.
For example: Two cars drive in the opposite direction on a straight road. After 6 Km they turn left and drive 8 Km. How should you be able to tell how far they are apart then? You don't know where they started, and if they mean roadkilometres or the actual distance.
That's easy:
The test says "they start from the SAME POINT" (which isn't possible, obviously, but the only way, to solve it)
You have to think about the scene: those curves are 90° angles.
so, you have to use the pytagoras:
8²+6²=64+36=100
100^0,5 = 10
so, they both changed their original position by 10 Km.
as they BOTH moved, you have to double that.
10*2=20
conclusion: the cars are 20 Km away from each other.
8²+6²=64+36=100
100^0,5 = 10
10*2=20
Users browsing this forum: Baidu [Spider] and 31 guests
