Mitsuba renderer
Re: Mitsuba renderer
Post by StompinTom » Wed Oct 03, 2012 4:11 am
CoolColJ wrote:Veach MLT - 10min render - only source of light is indirect lighting through windows and geometry seams :P
No exit portals or anything here :shock:
Wanted to see how many samples to reach a clean shadows with Veach MLT
8192 samples here - 30 min render
Cool! How are you exporting scenes to Mitsuba? Only found the older exporter and haven't tested it yet... Does it work?
CoolColJ
Post by CoolColJ » Wed Oct 03, 2012 11:01 am
I'm just importing OBJ scenes, it will also load DAE and another format
And I guess you can edit the saved XML scene files, after importing, like old schoool Indigo :)
Alain
Post by Alain » Thu Oct 04, 2012 1:22 am
Ok I export a OBJ-File.
But does a OBJ-File also contain the lightsources from my Blenderfile ?
And how do I have to setup Materials, Sunlight,... ?
Do I have to edit an *.xml file ?
BTW: It also supports instancing geometry, see here: http://www.mitsuba-renderer.org/devblog/
Did anyone did some heavy test with complex Interiorscenes yet ?
Kind regards
Alain
Win 7 64 Bit, 8 GB RAM, Geforce GTX 480, Blender 2.62, Indigo RT Trial, Blendigo 3.2.12.0
CoolColJ
Post by CoolColJ » Thu Oct 04, 2012 6:59 am
Alain wrote:Ok I export a OBJ-File.
Kind regards
Alain
You might be better off exporting Collada 1.4 .DAE file format
But there is a Blender exporter of sorts done by someone. Mitsuba will convert it to the new scene format if it's old in any case.
http://bartoszstyperek.wordpress.com/20 ... -exporter/
I don't know Blender well enough to get it to work, where to put it, which of the million versions of Blender to use etc etc :?
CoolColJ
Post by CoolColJ » Fri Oct 12, 2012 9:46 am
Mitsuba was updated again, better .OBJ and .DAE import.
I finally got this scene into it, but there are some shading errors I need to sort out :)
I hand edited the water in.
12 min or so render! Very quick on the caustics - by far the fastest unbiased renderer in this aspect 8)
Manifold Perturbation is like magic for this, Indigo needs this! :shock:
I've done this scene in Indigo and Luxrender and it's pretty slow. 2 objects sitting in water
15-20mins in Mitsuba
CoolColJ
Post by CoolColJ » Sat Oct 20, 2012 7:38 pm
Blender Mitsuba exporter has been updated!
http://bartoszstyperek.wordpress.com/20 ... orter-1-0/
Post by Pibuz » Sat Oct 20, 2012 9:39 pm
I WANT A SKETCHUP EXPORTER!!!!!!!!
