Subsurf in blender not work...
Subsurf in blender not work logical in Indigo.What i mean?When i set render level hight only to the "render level",when i export and start indigo process,actually i mark that my objects was not render whith "render level" i put,but whit render "level" i put in modeling progress.What happen?What i cant understand ?Maybe i am wrong about all of this but i dont know what to do,and ask you for comments.
This is my understanding, someone correct me if I'm wrong.
The "Render Level" shows how much subsurf will be applied by the internal Blender rendering. When you use Indigo you are not using the Blender internal renderer. That subsurf is not in the geometry of the mesh. The subsurf "Levels" is applied to the geometry of the mesh. Only the geometry of the mesh is exported to Indigo, the "Render Levels" is ignored. So nothing is broken. You need to make your subsurf using "Levels" not "Render Levels".
- deltaepsylon
Results are quite unpredictable if you don't apply your modifiers.
qinjuehang
