[Mac Bug?] Matrix not invertible error
11 posts • Page 1 of 1
Post by Whaat » Thu Nov 12, 2009 2:19 pm
I have a scene that renders fine on Vista Home Premium 32 but I get an error rendering the exact same scene on Mac OSX 10.5.8.
Is this a bug or something that I need to fix with regards to SkIndigo export? Please have a look.
http://www.box.net/shared/jei28l5ths
Re: [Mac Bug?] Matrix not invertible error
Post by zeitmeister » Thu Nov 12, 2009 8:06 pm
No problems here on my iMac; OS X 10.5.8, Indigo 2.0.10 32bit. :?
I can test it later on my other 64bit-machine...
matsta
Post by matsta » Thu Nov 12, 2009 8:44 pm
Hey whaat. I got that same issue a while back. It has to do with the size of your mesh, I found that when i modelled small i often recieved this error. to fix i just up'd the size of my scene or just the smallest part of it.
hope it helps
regards
Post by Whaat » Fri Nov 13, 2009 4:36 am
@zeit: :shock: Please tell me that someone (on Mac) can reproduce this error! I thought it might have to do with the values in the rotation matrix being so small. (Like 1.7E-47 or something) Thanks for testing, though!
One thing though..I think I was using Indigo 2.0.8 (Mac) when I tested. Maybe I'll try with a newer version...
Post by zeitmeister » Fri Nov 13, 2009 5:20 am
Whaat,
2.0.10 is the latest official Indigo 32bit-build that runs on 32bit Macs... all newer builds are 64bit only.
Glad I could help!
Jeff Hammond
Post by Jeff Hammond » Fri Nov 13, 2009 6:40 am
Whaat wrote:Please tell me that someone (on Mac) can reproduce this error!
i get the same error:
Error: SceneLoaderExcep: ObjectExcep: transformation matrix is not invertible (In element 'model', around line 2840, column 5)
indigo v2.2.1 os x
Post by Whaat » Fri Nov 13, 2009 9:04 am
Aha! Thanks Jeff!
I will try with another Indigo version and see if I get the error.
Post by zeitmeister » Fri Nov 13, 2009 8:55 pm
AND HERE IT COMES!
This time on a Mac Pro 8Core, Mac OS X 10.5.8.
Indigo v2.0.12 32bit:
Indigo v2.2.1 64bit:
Maybe a 64bit rounding error?
draconic
Post by draconic » Sat Mar 26, 2011 9:14 pm
Do we have a solution for this bug? I'm trying to render in MAC but indigo keeps telling me this annoying bug.
But my scene works fine in windows
Post by fused » Sun Mar 27, 2011 1:47 am
draconic wrote:Hi,
Hey draconic,
what version of Indigo and which exporter are you using (also which version)?
Regards,
Yves
draconic
Post by draconic » Sun Mar 27, 2011 8:24 am
it's 2.6.1 I'm using sketchup as an exporter and it's also 2.6.1 version
