Memory Allocation failure
10 posts • Page 1 of 1
carolyn_blake@gspnet.com
Post by carolyn_blake@gspnet.com » Tue Jul 14, 2009 4:59 am
Hey Everyone,
I have modeled a chapel in SketchUp and Indigo won't launch. It gets to subdivision 9 in the little dialogue box and then stops. The message I get is "indigo diverexcep: Memory allocation failure when initializing indigo." I have done everything I can think of to simplify the model, including exploding components. I have also been able to get large sections of the chapel to render, just not the whole thing. This is part of a much larger model, and I have successfully rendered other views. Please help!!
Godzilla
Re: Memory Allocation failure
Post by Godzilla » Tue Jul 14, 2009 5:01 am
How much Memory (RAM) do you have?
Post by carolyn_blake@gspnet.com » Tue Jul 14, 2009 5:02 am
3.25 GB
Post by carolyn_blake@gspnet.com » Tue Jul 14, 2009 5:04 am
intel q6600@ 2.40Ghz
cpfresh
Post by cpfresh » Tue Jul 14, 2009 5:05 am
thats a ton of subdivision .. is it really necessary? reducing that setting would help with this error.
Post by carolyn_blake@gspnet.com » Tue Jul 14, 2009 5:14 am
how do i do that? I didn't adjust the subdivision setting that I know of...
cpfresh
Post by cpfresh » Tue Jul 14, 2009 5:57 am
what version of skindigo are you using? you may not have changed it, it may have been the default setting, but like i said, it may not be necessary to have it set so high. in fact, are you even intending to subdivide a material in your model?
Post by carolyn_blake@gspnet.com » Tue Jul 14, 2009 7:39 am
I am using the 1.18 version. I don't even know what subdivision is...how do I change that? I looked in render settings and didn't see it.
cpfresh
Post by cpfresh » Tue Jul 14, 2009 6:01 pm
was there a skindigo version 1.1.18? the setting you're looking for should be in the material editor window under mesh subdivision. select the culprit material and then you can reduce the max subdivisions number there. you might also consider setting the displace setting to 0 to disable subdivision. hope this helps. gl
Post by carolyn_blake@gspnet.com » Wed Jul 15, 2009 12:38 am
worked like a champ! Thank you so much!!
