xrok1
by xrok1 » Mon Dec 31, 2007 10:28 am
for the last weak or so indigo has been crashing on my after between 15 and 50 minutes. i can't figure out why. i tried reinstalling going from 101 to 104 and the results are identical.
any ideas
I'm running Vista premium BTW and i never had this problem before
Behrendt
by Behrendt » Mon Dec 31, 2007 10:33 am
Always the same scene? Had this problem in a scene of mine. It seemed like the polycount of my meshlights had something to do with it. After i reduced it, it worked fine.
xrok1
by xrok1 » Mon Dec 31, 2007 10:37 am
I'll try a diferent scene and see. I have been working on the same scene for a while now.
Wedge
by Wedge » Mon Dec 31, 2007 11:50 am
Could it be that your computer is overheating?
xrok1
by xrok1 » Mon Dec 31, 2007 4:29 pm
tried a different scene and its fine.
that really bites though, cause the crashing scene is a reno i'm working on and i'm NOT going to redo it.
i'll try the problem scene from a different camera and see if that works cause thats the last change i can remember is trying to render through a new camera angle.
xrok1
by xrok1 » Mon Dec 31, 2007 5:31 pm
i wonder if i was to post the .skp file if Ono or someone in the know would be interested in tking a look at it?
by Kram1032 » Wed Jan 02, 2008 1:30 am
just an idea...
Try to open a new project/scene/what ever and then just overtake the meshes from the old scene....
You could also try, if you can first export it as obj and then reimport it back...
xrok1
by xrok1 » Wed Jan 02, 2008 1:25 pm
i tried a select all/cut from old file, then paste in a new file and it seemed to be fine weird
now i'm trying to move my portals in the old file cause i noticed they were misaligned for some reason? i'll post results.
xrok1
by xrok1 » Fri Jan 04, 2008 8:50 am
working fine again!
by Kram1032 » Fri Jan 04, 2008 11:04 am
good
Bogey Jammer
by Bogey Jammer » Tue Jun 17, 2008 8:06 pm
Sorry to get back this topic again but I had an Indigo crash after 10 hours of rendering (1.0.9 with vista premium 32bits). It is the first time it happened to me but I used many mesh emitters in my scene.
The questions:
- Is there really a mesh emitter limitation? (faces or mesh?)
- Does something in the computer (eg the RAM) overflow?
- It is risky to render a very complex scene with a weak computer? (I need to render this scene for 80hours to get 8000 samples/pixels)
- Is the problem coming from something else?
by CTZn » Wed Jun 18, 2008 12:42 am
My two cents but that could be 32 bits overflow.
zsouthboy
by zsouthboy » Wed Jun 18, 2008 1:51 am
CTZn wrote:My two cents but that could be 32 bits overflow.
Nonsense. I've rendered more than one scene for weeks with 32-bit builds (and FYI 32-bit build doesn't mean you can't have longs and doubles)
by Kram1032 » Wed Jun 18, 2008 5:01 am
zsouthboy wrote:CTZn wrote:My two cents but that could be 32 bits overflow.
I guess, that depends on your rig...
Though, it's strange that such an error occurs after 10h. A RAM overflow usually happens earlier and/or gives an error message...
There shouldn't be any emitter limit.
zsouthboy
by zsouthboy » Wed Jun 18, 2008 5:11 am
More than likely - it's 1) a hardware problem or 2) a threading problem.
Both are plausable.
Hard problem could include drivers deciding to misbehave, or simple over heating, or a RAM stick with some soft errors that only occur when some address is accessed in a specific way.
Threading problem could be an (unintentionally) thread-unsafe portion of Indigo simply grabbing the wrong resource at the wrong time, under some very specific circumstances.
