ortega
by ortega » Fri Aug 24, 2007 3:35 am
Well ... im trying make a scene with env. map + emitter, but when a do render with emitter the env. map do dark ... buuuut when i turn emitter off he work ... look the examples and sry about my english
Emiiter ON + Env. MAP
Emitter OFF + Env. MAP
btw...its the second time with same problem
thx
I use, Indigo_v09_test06 + Blendigo 9 s2
by Kram1032 » Fri Aug 24, 2007 3:42 am
that's 'cause you use reinhard tonemapping... (reinhard auto exposures your pic as good as possible, it tries to avoid pure black and pure white pixels)
two ways to get arround that:
1) make your emitter weaker (don't turn it completely off, but make it weaker)
2) use linear tonemapping - a bit harder to use than reinhard, but as long as you export the igi and you can post edit the tonemapping in violet, you shouldn't have troubles with that
by Zom-B » Fri Aug 24, 2007 3:44 am
its an tonemapping issue!
Black Body is sooooo bright that much more bright could not go!
So use efficiacy_scale for your meshlights, but finding the right values is a try & error work.
You also could try to reduce your Black_body gain value massively!
SmartDen
by SmartDen » Fri Aug 24, 2007 3:54 am
Just raise Env map gain
zsouthboy
by zsouthboy » Fri Aug 24, 2007 4:12 am
Smartden hit the nail on the head.
Just increase your Env map gain. by 10x or more
SmartDen
by SmartDen » Fri Aug 24, 2007 4:27 am
zsouthboy wrote:Smartden hit the nail on the head.
5 or 7 should be enough too. Just try out!
ortega
by ortega » Fri Aug 24, 2007 10:19 am
THX guys
Marcofly
by Marcofly » Fri Aug 24, 2007 7:59 pm
since when can you use env.maps +emitter? did i miss something?
by OnoSendai » Fri Aug 24, 2007 9:42 pm
Since always
Marcofly
by Marcofly » Fri Aug 24, 2007 10:22 pm
uh oh..
tnx Nick!
ortega
by ortega » Fri Aug 24, 2007 11:38 pm
how is better? only emitters? thx
SmartDen
by SmartDen » Sat Aug 25, 2007 12:15 am
ortega wrote:how is better? only emitters? thx
Try both, emitters and EXR. With emitter you can get good shadows and EXR give you nice revlections
deltaepsylon
by deltaepsylon » Sat Aug 25, 2007 12:17 am
I guess its better with only emitters. BUT (and its a big but) only if you add some other low power emitters (perhaps 2) around the model, i mean like long rectangular boxes so that you dont get 2 funky shadows. that way, the scene will still be bright, but you will still see the headlamp thing.
-OR-
you could go for a nice smokey.foggy effect and put the whole thing in a giant SSS cube and see the headlamp from the model illuminate a cone of light, that'd be pretty kewl
mind uploading the blend file? id like to take a closer look at that thing, looks interesting
deltaepsylon
by deltaepsylon » Sat Aug 25, 2007 2:59 am
kewl, tahnks
