REQ - Sky model without the sun
Hey, it would be nice if you can get that nice modelled sky up for renders, but without the Sun shinig to do cloudy days for example
thanks
thanks
- deltaepsylon
yeah, but I want the sky and the blend of the horizon and upper atmosphere colours etc - otherwise I would just use a background colour or image, but that doesn't look the same
or have a brightness parameter for the Sun would do the trick without too much complication I gather. This way we can simulate different enviroments or other planets
A Vue 6 Astmosphere/Sky model would be even better
- deltaepsylon
clouds shouldnt be THAT hard?
prob. cuz he was trying to do it a diferrent way.
My way ----> generte the shape in 2d, then map it onto EXR/HDRI (i get em confused too much) and then use that as a background. the most time consuming part of that would be the saving as an exr/hdri thingy.
but you would only need to generate fractals, and thats easy/quick in 2d
nope xD
very low values (1.5 and lower) give a black sky, where the sun is white, very high values give greenish skys, where the sun is white, too
Dunno, the exact "correct" range, but tinman posted, somewhere, that minimum for correct values = 1.8 or something like this, and maximum = 6...
lower and higher values will give incorrect results - not shure, if these are correct, or if they're exactly, what tinman wrote...
- deltaepsylon
