skip further subdivisions levels under conditions
5 posts • Page 1 of 1
Post by CTZn » Tue Oct 21, 2014 3:38 am
skip further subdivisions levels attempts if no quads nor tris where modified during the last level. is this a safe condition ?
kklors
Re: skip further subdivisions levels under conditions
Post by kklors » Tue Oct 21, 2014 9:16 am
Usually when I run into ram issues because of displacements I just roughly estimate right subdivs by checking the displacement map res in megapixel. Basically a 2048x2048 map would have 4.19 MP for example, so it wouldn't show more detail with more than 4.2 million quads. So a 1 mil plane with a subdiv of 1 would be already pretty much there etc. So I think the displacement map res vs. poly count on object is a good condition.
However not so sure what happens after it triangulates the quads. It shouldn't give more detail after that, right?
Post by Zom-B » Tue Oct 21, 2014 11:16 am
I simply use the Pixel Threshold to limit the subdivision, its only important to know that the Pixel Threshold is applied on internal resolution, before Super Sampling!
Post by CTZn » Thu Oct 23, 2014 8:44 am
pixel threshold is a must and working magnificently. It is sadly ineffective in spherical mode, the functionality being skipped/ignored.
I can manage the RAM well but as it is with subdivisions conditions being ignored with the spherical camera the poles are looking ugly downstairs. now that's maybe because I didn't test the resulting map in conditions but stared at its renderingninstead. can it be so ?
kklors, I'll ignore you if you talk about texels again to me in the next days :lol: good tip of course.
Post by CTZn » Fri Oct 31, 2014 3:46 am
This seems to be true partially. View-dependednt subdivisions seem to apply with the spherical camera, but the distance ought to be modified by some logarithm I'm guessing. There must be an optimum view-dependent algorithm specific to the spherical camera mode.
On a different note, swapping camera types may render the view-dependent optimisation strictly inoperating in some instances.
I hope I clarified the report somewhat.
