SSP limit / Halt Time Adjustability during render
5 posts • Page 1 of 1
Voytech
Post by Voytech » Fri May 16, 2014 6:31 am
Would it be possible to enable the changing of ssp and halt time limits once render is started?
yonosoy
Re: SSP limit / Halt Time Adjustability during render
Post by yonosoy » Fri May 16, 2014 6:38 am
Try to change it in the queue list (it should work, but never tested) .
Post by Zom-B » Fri May 16, 2014 6:29 pm
Yes, you can edit the halt parameters in the render Q BUT:
if you wanna go for 1000 and start typing 1... render halts immediately -.-
So you need to copy & past a value here!
The predefined halt condition is still valid, so once reached before the Render Q value... render halts!
yonosoy
Post by yonosoy » Fri May 16, 2014 7:01 pm
Curiosities...
Then, if high values are defined in the inifile.xml and pasting the values carefully ... Works?
In the inifile.xml is about to add this two lines in the render settings section with the desired max. parameter:
		<halt_time>-1</halt_time>
		<halt_samples_per_pixel>-1</halt_samples_per_pixel>
Thanks in advanced.
EDIT: works fine, thanks for the tip, Zom-B.
the value of -1 means no halt>infinite time, spp...
Voytech
Post by Voytech » Fri May 16, 2014 11:50 pm
Ahh, nice workaround! Thanks to the both of you!
