[req] Adjust colour temperature of image in gui
7 posts • Page 1 of 1
William
Post by William » Fri Feb 01, 2013 11:23 am
It would be convenient to have a colour temperature adjustment in the Indigo GUI. (for the entire image)
Re: [req] Adjust colour temperature of image in gui
Post by CTZn » Fri Feb 01, 2013 11:29 am
The white point controls are for this purpose. They are found between the tonemapping and histogram tabs in the Render Settings, and come with presets.
William
Post by William » Fri Feb 01, 2013 11:37 am
Well yes of course. The reason is that x/y controls are ridiculous to expect anyone to set manually and the presets are too far between.
Post by pixie » Fri Feb 01, 2013 11:44 am
William wrote:Well yes of course. The reason is that x/y controls are ridiculous to expect anyone to set manually and the presets are too far between.
Pick a pixel on the picture itself, it works fine for me.
William
Post by William » Fri Feb 01, 2013 11:46 am
I don't want to set white specifically but instead desire to adjust the temperature (ie warm/cold on a camera)
FakeShamus
Post by FakeShamus » Fri Feb 01, 2013 12:19 pm
maybe adjust the temp of your light source, then?
Edit: by the way, using the white point picker doesn't change the tone mapping or exposure of your image, just recalibrates what reads as "neutral"
William
Post by William » Fri Feb 01, 2013 3:50 pm
Could also be done in photoshop. It's all about convenience and interaction/tweaking which can help you achieve the better result.
Your right though tweaking the light layer can work in a similar way, but setting the light layer temperature damages it's colour in an unattractive way (for example the sun will go too blue or green).
