ISL help
chubakueno
ISL help
I'm working on a shader that blend towo textures with the "burn" equation. The problem is that I need to divide two vec3's and Indigo doesn't have that feature.¿Someone can help me?
I = Top Layer
M =Back Layer
I = Top Layer
M =Back Layer
- layer-mode-burn.png (4.65 KiB) Viewed 16552 times
Re: ISL help
Hey, I really want to help you, but I'm not sure how the division should work.
Read this: http://www.mcasco.com/qa_vdq.html
In vectors there are two ways of multiplying, the dot product and the cross product.
dot division is not defined.
cross division is also undefined.
chubakueno
Re: ISL help
I mean tex1 (r1,g1,b1)/ tex2 (r2,g2,b2) = result (r1/r2,g1/g2,b1/b2)
Re: ISL help
okay, here we go:
another question of understanding: are the components assumed to be in the range of 0-255 for this function?
def div(vec3 a, vec3 b) vec3: vec3(doti(a) / doti(b), dotj(a) / dotj(b), dotk(a) / dotk(b))-
chubakueno
Re: ISL help
Yes, but it can be easily converted from 0-255 to 0-1. I'm testing...
chubakueno
Re: ISL help
Thanks Fused, it works!
Now I'm doing overlay, screen, etc
edit:: I think blending modes can be bundled into exporters.
Re: ISL help
Nice work chubaka,chubakueno wrote:Thanks Fused, it works!
I'm sure if you release your code you could speed up the Exporter integration
Re: ISL help
Oh yes!ZomB wrote:Nice work chubaka,chubakueno wrote:Thanks Fused, it works!
If you post all your shader when youre done it will make its way into the ISL blend shader in cindigo
chubakueno
Re: ISL help
Overlay:
Normal:
Invert:(only the camouflage)
edit:Later I'll post the other blending modes
<![CDATA[
def overlay(real it1, real jt1, real kt1, real it2, real jt2, real kt2) vec3:
vec3(div(mul(div(it1,255.0),add(it1,mul(div(mul(2.0,it2),255.0),sub(255.0,it1)))),255.0),
div(mul(div(jt1,255.0),add(jt1,mul(div(mul(2.0,jt2),255.0),sub(255.0,jt1)))),255.0),
div(mul(div(kt1,255.0),add(kt1,mul(div(mul(2.0,kt2),255.0),sub(255.0,kt1)))),255.0)
def eval(vec3 pos) vec3 :
overlay(
doti(sample2DTextureVec3(0,getTexCoords(0)))*255.0,
dotj(sample2DTextureVec3(0,getTexCoords(0)))*255.0,
dotk(sample2DTextureVec3(0,getTexCoords(0)))*255.0,
doti(sample2DTextureVec3(1,getTexCoords(0)))*255.0,
dotj(sample2DTextureVec3(1,getTexCoords(0)))*255.0,
dotk(sample2DTextureVec3(1,getTexCoords(0)))*255.0
<![CDATA[
def substract(real it1, real jt1, real kt1, real it2, real jt2, real kt2) vec3:
vec3(div(add(mul(it1,0.5),mul(it2,0.5)),255.0),
div(add(mul(jt1,0.5),mul(jt2,0.5)),255.0),
div(add(mul(kt1,0.5),mul(kt2,0.5)),255.0)
substract(
<![CDATA[
def substract(vec3 col1, vec3 colt) vec3:
sub(col1,colt)
substract((vec3(1.0)),
Re: ISL help
wow, pretty nice, a few nitpicks if you dont mind
in the invert shader, you dont really need a subtract() finction. i fact you dont even have to use the sub() function. just use operators:
in the other two shaders:
is the same thing as
and then passing that to the overlay/subtract function.
a few other optimizations/simplifications for your normal shader:
not tested tho
vec3(1.0) - sample2DTextureVec3(0,getTexCoords(0))in the other two shaders:
dotk(sample2DTextureVec3(0,getTexCoords(0)))*255.0,Code: Select all
sample2DTextureVec3(0,getTexCoords(0)) * 255.0a few other optimizations/simplifications for your normal shader:
def substract(vec3 v1, vec3 v2) vec3:
div((v1 * 0.5) + (v2 * 0.5), 255.0)
substract(
sample2DTextureVec3(0,getTexCoords(0))*255.0,
sample2DTextureVec3(1,getTexCoords(0))*255.0
chubakueno
Re: ISL help
Yes, but you can't divide a vec3 with a real.edit:And thanks for the optimizations.
Re: ISL help
easy fixchubakueno wrote:Yes, but you can't divide a vec3 with a real.
div((v1 * 0.5) + (v2 * 0.5), vec3(255.0))Code: Select all
def div(vec3 a, real b) vec3: vec3(doti(a) / b, dotj(a) / b, dotk(a) / b)-
chubakueno
Re: ISL help
In general, you can't divide vec3's, only real vs real
Re: ISL help
sorry but that is what you asked for in the beginning. then I told you its not possible and you said what you meant. Then I wrote a function that does exactly that. And now you tell me its not possible.... hello?
fused wrote:Code: Select all
