[REQ] sun and hdri lighting
- Kosmokrator
the topic say it all....it wold be ideal to have lighting setup based on sunlight system and exr maps ....what u think?
Hi! I think that sun+exr is useful because with sun you have very sharp shadows like in sunny day, and with exr you have clouds and light changes around 360° (your object shall be illuminated differently around 360°)! I think!SmartDen wrote:Is this really needed? If you use a exr lighing u have already a Sun-lightsource naturally. You can add some emitter light, but i don't sure if it works.
And lighting with a jpg is a humbug! Jpg have not enough light information to illuminate a scene.
Solution with emitter and exr... maybe good for sharp shadows!! I'll test!
I don't think it's trivial. Sun drops parallel shadows, also you have to simulate this. And you must find an exact position of strongest light source in exr image also.8bstudio wrote:It seems work well exr+sun_emitter... mmmhh! Very good!
Now I must search dimension (x and y) of emitter to simulate real sun shadow. ...
here "sun version"
http://www.8bstudio.com/bonus/chiosco4-sun.zip
Hi Radiance!
Here xml: http://www.8bstudio.com/bonus/chiosco4-exr-emit.zip
Try to change around "linear scale" or meshlight named "Plane"
I hope it's usefull for you!
Bye!
Bye!
Hi !
I think that one could use LightGen's plugin for HDRShop to define a directional light. Then the rotation has to be translated into a vector, that's a very few maths wich I don't know, sorry... or try to hack into some of the output files format generated, who knows ?
So it's about importance sampling, a simple app or even simpler: send a template of an xml scene with sun to the author:
Would you ask Radiance ? I'm too new with Indigo to be positive on what features have to be implemented...
LightGen for HDRShop
Just ask him to put 1 directional only, then compute the vector ! That'll be so easy I'm sure he will !If you want a new file format, be sure to send me a template for the file that the plugin should generate.
