the same composition renders differently the env-map between 1.1.6 and 1.0.9: look out of the window (no glass), 109 is ok, 116 is just yellow/brown.
<env_map>
<latlong>
<path>../../pisa.exr</path>
<gain>4E+8</gain>
</latlong>
</env_map>
<camera>
<pos> -1.609610901 -3.138067017 2.098994751</pos>
<up> 0.081756617 0.093759003 0.992232385</up>
<forwards> 0.652112407 0.747846584 -0.124398131</forwards>
<aperture_radius>0.000075</aperture_radius>
<focus_distance>2.0000</focus_distance>
<aspect_ratio>1.3333333333333333</aspect_ratio>
<sensor_width>0.036</sensor_width>
<lens_sensor_dist>0.06717691453623979</lens_sensor_dist>
<white_balance>E</white_balance>
<autofocus/>
<exposure_duration>0.0025</exposure_duration>
ENV-MAP and ExitPortal bugs in 1.1.6 ?
- 1.0.9 after a few seconds: ok
- 109.jpg (32.55 KiB) Viewed 7264 times
- 1.1.6 after a few seconds: brown ?
- 116a.jpg (31.37 KiB) Viewed 7264 times
no, that's not what I meant xD
sry, wrong word...
"double thread" is correct: you posted the same problem twice
although... the pictures are different... hum... strange^^
http://www.indigorenderer.com/joomla/fo ... php?t=5348
so, it IS a different bug?
sry, wrong word...
Ok, now I've understood what you mean...
Yes, I think to have found two different bugs:
this one is about env-map, looking brown instead of showing the correct image, the other thread is about exit portals: with 1.1.6 the window is black, with 1.0.9 I can see through the windows.
The scene in this thread is always the same, but without exit_portals.
The full story was:
"Ok, good scene, let's try with Indigo 1.1.6..."
A) sigh! black window... let's try without exit portal
B) Ok, without exit portal (first bug) now I can see throw the window, but I see all brown (second bug)
With 1.0.9.3 everithing works well even under Linux 64bit. I can't try 1.1.6 on linux because I've a problem loading jpegs, but it is a dynamic library problem...
The full story was:
