Crash after 15-50 mins.
- Bogey Jammer
argh, I made the simplified scene with all the emitting meshes and it didn't crashed..
Since I don't have time to render the same scene again for ten and ten hours I temporary conclude that my scenes must be quite balanced for safe rendering on my hardware...
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
- Acer aspire 5612Zwlmi
- Intel T2060 dual core 1.6 GHz
- 1GB RAM
- vista home premium 32bit
- Bogey Jammer
What I meant is when I render the emitters+complex scene, it crashes. But not the complex scene without the emitters or the emitters+simplified scene. So the meaning of balanced is that I must simplify both the scene and emitters in some way to succeed. Because after theses test I could not find the problem origin and it is probable that it comes from my computer.
I apologize for not telling more useful since I can't do very much to step forward in this problem and my computer wants to sleep
- 1GB RAM
Sayris just got such an Problem with a scene too.
its crashing from 1 to 15 minutes after render started, on my system too.
So I'll try to reduce this 0.5million Poly bitch... until then I attached the 3 error log Files my Vista 64bit produced on Crash zipped.
- error_output.zip
- (157.3 KiB) Downloaded 167 times
Crash Here with blendIndigo 1.0.9 and indigo 1.0.9 On Ubuntu 7.10 after more 1hour... problem with wine
http://friendpaste.com/JAxkYm2b
http://friendpaste.com/WVQY7E5p
Athlon xp 2600 1go ram
thx
thx
I had a strange crashing in my new scene...it works fine about 4 hours then Indigo send an error but if i dont click on the button for close the error window the render continue his work....
Any ideas??? I could like to try with Suvakas solution but in Blendigo where is this choise??? "BIH" "KD-TREE"???
Luca.
Luca.
I'm just starting with Indigo and sketchup and do not know ANYTHING about the technical side of renderers. I've had similar crashes with VERY simple scenes - in my case, Indigo crashes when I render using MLT but not with BiMLT.
I have not yet found a good explanation of what the differences are between all of the options - any suggestions for me?
Users browsing this forum: No registered users and 46 guests
