Weird behavior on diffuse material
9 posts • Page 1 of 1
lekane
Post by lekane » Fri Nov 10, 2006 5:47 am
ok here is the problem
on the right of the right building... black area...
it should be like the rest of the building...
Material is diffuse
When i turn the building so that this part faces more the cam.. it turns out ok... so perhaps it has to do with the angle with cam i dunno.... if you want the .blend i still have it...
(btw indigo 0.6b6)
(oh and sorry for abd english ) :D
Kosmokrator
Post by Kosmokrator » Fri Nov 10, 2006 6:08 am
classic normals problem man...flip the normals .... :wink:
lekane
Post by lekane » Fri Nov 10, 2006 6:11 am
My normals are ok (i RE-checked after reading your msg)...
In fact, rotating the building would show me black faces if it was a normal problem...
arneoog
Post by arneoog » Fri Nov 10, 2006 6:21 am
Turn off Normal_Smoothing on the buildings :)
lekane
Post by lekane » Fri Nov 10, 2006 6:27 am
there is no normal smoothing :roll:
arneoog
Post by arneoog » Fri Nov 10, 2006 6:58 am
In the XML file?
In the model attribute part
<normal_smoothing>false</normal_smoothing>
lekane
Post by lekane » Fri Nov 10, 2006 8:16 am
is it false by default?? cause i dont have such a line....
boweeb007
Post by boweeb007 » Sat Nov 11, 2006 12:59 am
Anything Indigo doesn't find in your scene file, will be read from your inifile.txt. So check in there, too.
Think of the inifile.txt as a way of setting your defaults.
lekane
Post by lekane » Sat Nov 11, 2006 1:54 am
i never used this file uh uh uh :lol:
I looked at it.. nothing about normal smoothing as i expected hehe
I have the feeling you all consider i'm doing something wrong...
So i'll post the blend and you'll show me :P
Users browsing this forum: Bing [Bot] and 41 guests
