Ok, so projects like Folding@Home take unused CPU cycles and do something with it.. so I think, why not create something like an indigo distributed screen saver, similar to electric sheep (electricsheep.org). I would be more than happy to devote my computer's down-time to other peoples' renders if it meant I could see some extremely high-mutation images.. and I'm sure other people would too, even if they aren't creating any renders themselves.
I admit I know nothing about coding, but if you've already got the basic server-client code, couldn't this be done? Judging from the renders I've seen, indigo's quality is spectacular; it's number one drawback right now is the debilitating speed. If there were several hundred computers devoted to high-quality renders all the time, the indigo project would have a constant stream of rendering power available.
It's a selfish request, but I want to see even MORE indigo use everywhere!
Thanks for such great software, and keep at it!
Request: Distributed Rendering Indigo Screen Saver!
- joegiampaoli
something like BOINC?
http://boinc.berkeley.edu
That would be neat!
But, I don't think many people will be intersted in helping on a project like that
That would be neat!
- joegiampaoli
something i hope one day (probably very far away) indigo will be able to use the gpu's calculation power to accelerate faster then a cpu ever could. they did that with holding at home, apparently they tested a core duo and a 1900xt and the 1900xt was several times faster.
Yes i know, my spelling sucks
Ah, that's true about the security issue. Screen savers are now one of the biggest ways viruses get onto a system. A reasonably secure screen saver that needs constant internet access does sound like a pretty big undertaking.
I think the hamachi idea would work well though! If I recall correctly, it lets you set up a private network, so there could be xml files in a shared folder somewhere that all users could access. Would it still require clients to manually start each render, or is there some way to run multiple files I wonder? Sign me up anways!
-KouOuKen
the clients have to start their render processeskououken wrote:Ah, that's true about the security issue. Screen savers are now one of the biggest ways viruses get onto a system. A reasonably secure screen saver that needs constant internet access does sound like a pretty big undertaking.
It's not a big problem as with Indigo anyone could join in the middle of the render or drop as soon as they need their pcs
Users browsing this forum: Google [Bot] and 90 guests
