inifiles
4 posts • Page 1 of 1
m1j
inifiles
Post by m1j » Thu Oct 19, 2006 6:50 am
With the rendering settings inside the file I would like to see indigo not require the ini files. It could be setup so that if these files are not found a default setup is used inside indigo until it finds the rendersettings in the xml file.
boweeb007
Post by boweeb007 » Thu Oct 19, 2006 2:42 pm
That's basically how it's set up already. I think having the ini file is better in this regard because you can easily change what the default settings are.
m1j
Post by m1j » Fri Oct 20, 2006 1:54 am
[quote="boweeb007"]That's basically how it's set up already. I think having the ini file is better in this regard because you can easily change what the default settings are.[/quote]
When I run indigo and the ini files are not present indigo complains. It is just as easy for me to edit the xml as it is to edit the ini file.
debris
Post by debris » Fri Oct 20, 2006 2:01 am
I have some problems starting indigo.exe remotely on many computers here, because it always complains about missing ini-files, although I have admin rights on all systems and all paths should be correct.
If I use the very same commandline locally everything renders fine.
So I would second getting rid of these ini-files, or maybe make them an option?
