hello
i am new here and unfortunatelly i found a bug
i am using indigo RT with skp 2019 pro and after exporting a scene some objects are strangely cutted out
BUT after i just move camera under horizont indigo render whole scene perfectly
it look s to me like some kind of clipping planes , yes its more then one /in horizontal and vertical direction/
i am using GPU render and want to use it /cpu is slow /
hardware : amd tr 1920-x and amd 6800 non xt
win 10 pro
here is the example :
problem is with background and models or dummies of cement silos /that yellow ones/
possible bug ?
Re: possible bug ?
Hey mate,
been some months since you asked but I give it a try anyway
Without some (simplified) example its always a best guess but I would say you have plenty of images with alpha in this scene and the raydepth of GPU rendering is to low.
Push it up to 99 and see if this issue is "fixed". If it is, then we have the reason. Now try to find the lowest needed raydepth value for your scene for maximum performance.
If this doesn't do the trick then think about uploading a reduced example file or PM it to me, so I can have a look
Users browsing this forum: Ahrefs [Bot] and 2 guests
