The GPU does not work in large scenes
Re: The GPU does not work in large scenes
"I still can not render a scene larger than the GPU memory."
I don't think your problem is solvable, unfortunately. You have relatively little video memory, yet want to render big scenes. Indigo doesn't have "out-of-core" GPU rendering, and NVIDIA GPUs are known to be more memory limited in OpenCL mode (which is probably why you can't allocate all of it). This is all explained here:
https://www.indigorenderer.com/document ... ring-guide
Your choice is to either upgrade to a better GPU (an AMD Vega 16 GB card would do nicely) or to optimise your scene to use less memory.
Good luck!
Good luck!
Hi Oleg,
Can you paste the contents of the Scene Info window in Indigo, when attempting a GPU render?
Hi, OnoSendai!
I attached a screenshot of Scene Info window and copy of render log.
- log.txt
- (14.76 KiB) Downloaded 885 times
Hi, Oscar J!
The problem is that for high quality work I need 30-60Gb of memory, and it is technically impossible for today. Nvidia has released professional video cards in 32Gb memory but by the autumn I expect the appearance of game video cards with the same volume but much cheaper. In this volume, I can fit, but still the artistic part of the work gets worse.
The most important difference of Indigo is the ability to focus on the artistic part of the work. If it was possible to work on the GPU without thinking about the polygons, as possible on the CPU - it would be incredibly productive!
Thanks for the help!
IIRC, newer AMD cards have the ability to use CPU RAM (offloading textures). Saw it work with Cycles.
If out-of-core rendering is possible with OpenCL then we can add it. OpenCL 2.0 adds 'shared virtual memory', which maybe does the trick.
Hi, OnoSendai!
I've tried a lot of renderengines, you are without a rival, and if you do this, it will be the ultimate victory.
I wish you success!
Thank you!
I wish you success!
Thank you!
Below is a link to posts about Cycles ability to offload textures (VRAM > sys RAM). It's also mentioned that latest AMD drivers give such ability without the need to code in app
>> Blenderartists Thread: Brecht's easter egg surprise: Modernizing shading and rendering (page 859)
Hello, burnin!
I had not considered AMD before. I've been studying it. It is interesting that with the performance/price parameters.
Thank you very much for the information!
