See images attached please.
Thank you!
Indigo problem with Skatter v.1 plugin-groups and components
Carpe diem...quam minimum credula postero...
Re: Indigo problem with Skatter v.1 plugin-groups and compon
Ludwolf76 wrote:See images attached please.
Thank you!
I have a problem with Skatter v.1.0 and Indigo…I can skatter grass presets and I can skatter everything if it’s a group…but I can’t if it’s a component…I have to fully explode it and than transform it to a group…than everything is fine...
With render only feature disabled it works…but now I’m confused a little bit…I tried with another component I made in sketchup...a simple box...and it works well with render only feature activated!!! Am I missing something? With every group I tried it works…and with components randomly works…sometime it works and sometime it doesn’t…strange…
This is the developers reply to my post in Skatter forum :
"After checking the file you sent me, it indeed seems to be related to Indigo itself. The Skatter setup is generated fine, it works with other render engines, but not with Indigo. So I’d recommand that you contact the Indigo developers, as I can’t fix this issue myself."
Could you please check Ono? Thank you for your answer and consideration.
Gian Luca
Gian Luca
Was this fixed?
