[REQ] Shadow Catcher material...
Re: [REQ] Shadow Catcher material...
Post by Zom-B » Thu Apr 11, 2013 4:23 am
OnoSendai wrote:I have added support for alpha < 1 for rays passing through glass windows etc:
Suuuuuper sweeeeeet!!!
vis4arch
Post by vis4arch » Thu Apr 11, 2013 5:15 am
that is just great!!!
all the best,
tamas
berg8 - werbeagentur
. design . web . marketing .
Post by StompinTom » Thu Apr 11, 2013 6:29 am
Amazing! Is this in the new release?
Post by OnoSendai » Thu Apr 11, 2013 6:49 am
Will be in 3.6.11 probably.
Post by zeitmeister » Thu Apr 11, 2013 7:28 am
So cool!
Post by OnoSendai » Thu Apr 18, 2013 2:18 am
Alpha < 1 for thin glass is in 3.6.11: http://www.indigorenderer.com/forum/vie ... =1&t=12309
dtoxic
Post by dtoxic » Wed Oct 02, 2013 1:14 pm
hello can some one point me in the right direction
here is my problem
whenever i try to combine in photoshop shadow pass with foreground pass (3d object with materials) and the background the object is a bit transparent and i can see the background behind it so if someone can just point me in the right direction cause i dont know what i;am doing wrong
P.S
shadow and foreground (object) are saved as png the backplate is jpg
thx in advance
here is the pic
http://s11.postimg.org/nzldsisg3/image.jpg
Post by Zom-B » Wed Oct 02, 2013 7:25 pm
Your main Pass simply needs to render longer :)
Use radial splatting to reduce that effect a little better.
A simple fix is also just to double your layer with the foreground rendering in PS.
The Shadowpass looks also like it could use some extra CPU time ;)
dtoxic
Post by dtoxic » Wed Oct 02, 2013 11:55 pm
thx for the tip i know my shadow needs more time to render it was just a qucik render to show the problem i;am having anyway ill leave it longer this time again thx for the tip :)
