[REQ] Backface-Culling!
- zeitmeister
Re: [REQ] Backface-Culling!
Yeah!
Hi !
Sorry to use this old topic but someone know if this feature is implemented ?
Cuucus
Cuucus
It isn't! Never thought it be that useful...
Only thing somehow related is Indigo's SubDiv, that has a ViewDependent setting where you can set a Pixel & Curvature Threshold, also meshes outside the camera view also don't get subdivided
Depends which feature, but the clipping planes to which the discussion has evolved have been implemented
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Yep, this one.galinette wrote:Depends which feature, but the clipping planes to which the discussion has evolved have been implemented
how can I use it, because I found nothing in the documentation.
Thx,
Cucus
How should we know without the info what Exporter you usecucus wrote:Yep, this one.
Afaik its not directly accessible from Indigos GUI atm...
Oops, sorry !
I use 3ds Max 2012 and Maxigo v3.0.7.
Btw, which version of Ingdigo has the clipping plane ?
Its in since Indigo 3.4.3.
Your old Maxigo is discontinued, and was rewrite from scratch, breaking any compatibility to the old version:
http://www.indigorenderer.com/forum/vie ... =9&t=11889
I have no idea how development is handled there, since it isn't a official Exporter anymore
The Official new Exporter from Subpixel is still in (slow) development:
http://www.indigorenderer.com/forum/vie ... =9&t=11368
Both Exporters don't support the clipping planes and both aren't compatible to your old scene & material setup!
Thanks for you clarification.
So, if I want to use this feature, what is the procedure ?
Cucus
Cucus
I think in your situation you need to know how your "Indigo future" will look like first regarding the exporter situation.cucus wrote:So, if I want to use this feature, what is the procedure ?
there are 4 "kind of" options:
- stay with old Maxigo version but wait for a new Indigo with GUI setup for Section Planes.
That would result in hand editing exported scenes all the time to render them... sucks hard!
- set your bet on the new 3D Max exporter and play the waiting game.
- set your bet on the (unofficial) Maxigo exporter from Suvakas and play the waiting game.
- Change to a 3D app with proper Exporter support
tar_gniK
- 3D Software: 3ds Max
@ Zom-B: Point 4 is sucks more than point 1. Right, so us Max users should change to Blender, Maya, SketchUp, C4D etc, re-build all scenes (even if one was to export to obj or another method - yawn), re-assign materials, not to mention having to get used to a different interface -- all because of inadequate exporter support? That is too much of a sacrifice.
I would add point 5:
- Add manually the section plane in the xml code of the .igs file... That should not be so difficult, even if not super user-friendly...
Notepad++ has a wonderful Indigo exporter that gets never out-of-date, and is fully cross-platform : File>Save Asgalinette wrote:I would add point 5:
I'm using it all the time...
I like this point, I use it all the time toogalinette wrote:I would add point 5:
But for the clipping I don't know what is the name of the attributs.
Can you help me Galinette, pls ?
Cucus
Section Planes get defined like that:
Point seems to be the positions and normal the rotation, I can be wrong here.
You'll also maybe need to adjust your IGS further to be compatible with newer Indigo versions.
<section_plane>
<uid>8</uid>
<name></name>
<point>0 0 0</point>
<normal>0 1 0</normal>
<cull_geometry>true</cull_geometry>
</section_plane>You'll also maybe need to adjust your IGS further to be compatible with newer Indigo versions.
