The anti reflect glass was for this work, will test later
Street and subway station
Hi all, here is my last work, a subway station. I just finished one render, a next one is in progress (inside subway station)
- Final ext.jpg (808.32 KiB) Viewed 14462 times
It's really good
two points to add to what BbB said:
The street texture has quite visible tiling. Any chance that you find a better map? I know, it's hard to find good textures, aimed for big areas... if you don't find any, it's ok.
the tree leaves look a bit strange. something is wrong with them, don't ask me. But when you're on it: It's very unlikely that the leaves are scattered around the trees in this small radius. You can use them for dirtying up the street
Looks good Vanessa!
The only thing I have to mention is the sky appears burnt out (burnt to white) in some renders. This is caused by too much tonemapping. I see it often in renders and it makes me sad because Indigo can display a nice realistic sky.
Here my last renders, the end for this job, I've spend enough time on it
(:oops: Last one is a bit "vaginal", no?
- Final plan.jpg (1.26 MiB) Viewed 14027 times
- Final int.jpg (545.88 KiB) Viewed 14030 times
- Final ext int.jpg (681.28 KiB) Viewed 14030 times
- Final ext.jpg (859.17 KiB) Viewed 14031 times
- Final ext 2.jpg (911.35 KiB) Viewed 14032 times
