Thanks for your kind comments everyone!
@ Maluminas:
easy to model but it took me a while to figure out!
Any program that you can get a spiral path with and then extrude along that path is good.
That is the easy way, I think you could also do it with array tools in some progs to get a spiral, also it's called a 'spring' tool sometimes I think.
The hard way would be to extrude a shape manually, though you could setup a macro if you know the angles you want
After that it's a piece of cake - just a matter of rotating all the parts into place and cutting and joining those that you want together. No maths or anything, because they're springs its just a load of 90degree rotations to get them aligned.
looong explanation
doh! anyways hope that helps!
EDITEDIT: oooeps why is it in the gallery twice? not that I mind lol!
If I post something on the forum should I avoid putting it in the 'new images upload' ??
sorry I think thats my fault..
