Another sss piece
Bandar
Another sss piece
Post by Bandar » Sat Jan 13, 2007 2:55 pm
I spent the last night with indigo_07 :wink:
Here is the first result:
Post by CTZn » Sat Jan 13, 2007 3:12 pm
Cool, are you a TopMod user ?
I have some difficulty to read the shape clearly, like its merging into some transparency... I can see there is sss but my concern is different... you got me ?
Bandar
Post by Bandar » Sat Jan 13, 2007 3:38 pm
Yep, that's TopMod.
Here is the blend to explore: http://butz-e-matic.de/pix/topmod_test3.blend
The transparency is due to my ignorance how all the values effect the new materialsystem.
Here is another version, that is less transparent:
And this might be the material that I used for the 2nd picture (don't remember, if i changed it in the meantime):
	<medium>
		<name>rubber</name>
		<ior>1.0</ior>
 		<rgb>
          			  <rgb>0 2 10</rgb>
        		 </rgb>
		<precedence>20</precedence>
		<subsurface_scattering>
         <rgb>
          			  <rgb>2 12 1</rgb>
        		 </rgb>
			<phase_function>
				<uniform><value>4</value></uniform>
			</phase_function>
		</subsurface_scattering>
	</medium>
	<material>
		<name>green</name>
      <specular>
			<internal_medium_name>rubber</internal_medium_name>
		</specular>
	</material>
IanC
Post by IanC » Sat Jan 13, 2007 4:04 pm
That is just beautiful.
Thanks for the code+file, I've found a scene that crashes in wine with those mats, but doesn't with yours.
domparis
Cool !!
Post by domparis » Sat Jan 13, 2007 6:20 pm
Very nice especially the second one, top notch !!!
and thanks for the code :)
Dom
manitwo
Post by manitwo » Sat Jan 13, 2007 9:54 pm
The second one is ... :shock: :shock: :shock:
thank you also for the settings :wink:
Phil
Post by Phil » Sat Jan 13, 2007 10:12 pm
Hi Bandar,
this is incredible :D , thanks a lot for sharing your model and settings!
Regards, Phil
zsouthboy
Post by zsouthboy » Sun Jan 14, 2007 2:52 am
Camox
Post by Camox » Sun Jan 14, 2007 3:07 am
:shock: awesome, and THX for sharing your settings. :D
greetz :wink:
Post by fused » Sun Jan 14, 2007 3:47 am
impressive :shock:
Bandar
Post by Bandar » Sun Jan 14, 2007 10:01 pm
And another one :roll:
I will post a png with higher res to the gallery...
And here are the material settings:
	<medium>
		<name>rubber</name>
		<ior>1.2</ior>
 		              <rgb>
          			  <rgb>0 0.45 0.5</rgb>
        		              </rgb>
		<precedence>10</precedence>
                                  <rgb>
          			     <rgb>0.1 0.5 5</rgb>
        		                </rgb>
			<phase_function>
			        <uniform><value>40</value></uniform>
			</phase_function>
	</medium>
	<material>
	     <name>green</name>
              <specular>
	     </specular>
	</material>
Post by OnoSendai » Sun Jan 14, 2007 10:15 pm
WOW...
that's just an amazing material!
congrats!
Bandar
Post by Bandar » Sun Jan 14, 2007 10:26 pm
And congrats + 100000 thanks to you for coding that incredible renderer!
manitwo
Post by manitwo » Mon Jan 15, 2007 12:57 am
incredible!
Lotuspec
Post by Lotuspec » Mon Jan 15, 2007 1:31 am
Bandar wrote:
			<phase_function>
			</phase_function>
What does "value" do in the phase function?
Users browsing this forum: No registered users and 108 guests
