Quick one - ligne roset catalogue
Post by BbB » Fri May 09, 2008 6:33 pm
A quick scene, trying to match an image in the ligne roset furniture catalogue (their site has a good pdf).
Modelled in Blender, rendered in 1.0.9 64 bits in two 10-hour sessions on a Quad core 2.4Ghz. Original size something like 2000x2400. Camera tonemapping.
Photo reference
Render
MESCH973
Post by MESCH973 » Fri May 09, 2008 8:28 pm
BbB absolute GREAT photo, GREAT model ..... congrat you are a master!!! :wink:
Post by Pibuz » Fri May 09, 2008 8:57 pm
Yes, stunning as always.....
But, a simple question: do you ever sleep? God, you have a son too!!! :lol:
Congratulations, mate!
Post by BbB » Fri May 09, 2008 10:30 pm
A girl, actually. They're far less work ;-)
enricocerica
Post by enricocerica » Fri May 09, 2008 11:24 pm
Very nice pictures. I really like the match boxes (if they are match boxes), they are organised very naturally, did you used the softbody or game engine to let them fall on the floor ?
Post by BbB » Fri May 09, 2008 11:46 pm
Thanks Enrico. I wish I knew how to use the physics engine. Haven't bothered learning it yet. These were placed by hand... A pain.
Post by Zom-B » Fri May 09, 2008 11:57 pm
a very nice result bbb, great as always :ab
But for my screen your purple couch is way to dark, the contrast to the rest of the scene seems somehow "unrealistic".
Also archiving this velvet Style kind a bit of fresnel for the material is kind of impossible for Indigo ATM... maybe a blend with an Oren Nayar + a phong with very low exponent + bump map could do the job... how did you solve it atm?
Maybe some more bumpness of the couch model would would reflect the light better like on the original at the left side... or only an additional lightsource could be used to generate some nicer highlight at this spot...
just my 2cent
Post by BbB » Sat May 10, 2008 12:31 am
ZomB
Thanks man. You're right about the couch. Perhaps the diffuse map is a bit dark. I could brighten it up in PShop.
I didn't even try to replicate the velvet material. I went for a pure diffuse mat here, which I agree is not quite right compared to the photo.
jurasek
Post by jurasek » Sat May 10, 2008 12:36 am
Great as always..;) what camera tone/iso settings? this is lit by emmiters?
greetz,
jur
Post by CTZn » Sat May 10, 2008 1:05 am
I pretty much seconds ZomB crits
The color bleeding in the ref is interesting... In fact I believe they used a dimm purple light on the left side, because the color bleeding is visible in the couch's shadows only.
Gengibre
Post by Gengibre » Sat May 10, 2008 3:23 am
Wow, great couch, and nice materials...
neepneep
Post by neepneep » Sat May 10, 2008 8:49 am
Camera matching in Blender is a pain in the hiney to do...and as you probably noticed, it is very difficult to get an accurate match.....
...but there is another way - if you want to get it more accurate then you should give Sketchup a shot - Sketchup's camera match feature is super quick and accurate once you get the hang of it. If you are using the Pro version then you can then export the camera position via Collada export and Blender can in turn import the Collada file
If you don't have access to the Pro version, then just use the free version of Sketchup and export to KML>rename to ZIP>open ZIP>extract Collada files>import to Blender :D
You would just need to change the frame size of the Blender camera to be the same as the photograph file (or just get the correct aspect ratio) and you also would need to adjust the lens size since that isn't exported in the Collada file (just tweak it by eye until it is as close as possible.)
:roll:
Edit: NICE couch! :D
kwistenbiebel
Post by kwistenbiebel » Sat May 10, 2008 1:18 pm
Amazing!
I just need to say it: Indigo output looks better than the commercial unbiased packages.
And it is lovely in the hands of artists like BbB.
Congrats.
Post by StompinTom » Sat May 10, 2008 1:36 pm
dat boyz got it down pat.
beta
Post by beta » Sat May 10, 2008 7:38 pm
awsome as always BbB :)
