supraserv
by supraserv » Fri May 25, 2007 7:49 am
Frosty glass with diffuse transmitter. Border gaussian blurred in GIMP (mainly to remove noise). Rendered for 7h at 1538x2183. Had to finish cooking it because of deadline but I will possibly go back to find out how much I can get out of it.
The words refer to three towns in my region.
- witraz_gotowe.jpg (213.17 KiB) Viewed 2694 times
by Kram1032 » Fri May 25, 2007 8:23 am
why didn't you use Violet-internal noiseremoveing?
Ok, i didn't use it either, yet, except in a quite clean test-render...
But I guess, it should be way better, than gausian blur...
supraserv
by supraserv » Fri May 25, 2007 8:29 am
The blur gave a look of a wall texture and a texture of concrete was actually applied to it. Violet was behaving badly when I tried to do bloom and chromatic aberration so I gave up.
by Kram1032 » Fri May 25, 2007 8:43 am
hum... strange...
cromatic dispersion wont look too good, with high values, I guess...
The standard is 0.001, right?
Doesn't matter: I mostly use 1/10 of the standard value.
which bloom are you using?
I guess, your tonemapping is reinhard?
What about glare?
supraserv
by supraserv » Sat May 26, 2007 9:03 am
THe real thing. DVD cover after printing. A photo
- okladka.jpg (95.4 KiB) Viewed 2536 times
zsouthboy
by zsouthboy » Sat May 26, 2007 3:21 pm
Can I be completely honest?
..you could've done that in photoshop and not waited 7h for the results.
I don't mean to downplay your work, it looks great.
But I don't see anything there that requires Indigo, IMO.
supraserv
by supraserv » Sat May 26, 2007 5:39 pm
Yeah, zsouthboy, that only turned out when the thing was done.
