the INDIGO neon sign
7 posts • Page 1 of 1
dougal2
Post by dougal2 » Thu Apr 12, 2007 11:10 am
is in the gallery:
http://www2.indigorenderer.com/joomla/i ... emId=16133
How I did it: (I'd like to share the knowledge, as I have needed the knowledge of others in the past ;) )
1. Create a text object in blender.
2. Convert it to a curve (ALT+C).
3. Create a small bezier circle, that has diameter=thickness of the neon tube that you want. Call it BevelCircle.
4. In the editing panel of your text (curve object) type BevelCircle in the BevOb: Field. The text now looks like soe closed tubes :)
5. Convert it to a mesh (ALT+C again).
6. Faff about for ages making all the breaks/joins, extra bits of tubes to make it all one piece. (this step took me the longest to complete).
What you now have is the outer, coloured part of the tubing.
I gave it this material:
Specular, glossy_transparent: exponent 400, precedence 10, ior 1.40, absorption RGB (1.0, 0.4, 0.05), SSS Uniform 7.0.
To make it glow:
1. Duplicate your tube mesh.
2. Go into edit mode, select all and Shrink/Fatten to make it smaller (ALT+S).
3. due to the conversion form curves, you may find that some of the mesh oes a bit weird or inside out. I spent time here tidying it up by hand. (this was the 2nd longest part of the procedure).
4. Give this thinner tube a LIGHT material: Blackbody gain 0.1, temperature 5000.
That's it. You may have to change your light gain according to your scene, of course. Mine was balanced against an EXR of gain 15.
The black parts of the tube I created in the same way, except using ALT+S to make it a bit larger, and then used a black diffuse material.
Big Fan
Post by Big Fan » Thu Apr 12, 2007 11:51 am
edited to remove all
Dacksoldier
Post by Dacksoldier » Thu Apr 12, 2007 2:48 pm
yay you beat me to it
i was trying to setup the vertical sign thing last night but it was too late and you beat me to making the sign
Iqwar
Thank You
Post by Iqwar » Thu Apr 12, 2007 5:54 pm
for sharing!
8bstudio
Post by 8bstudio » Thu Apr 12, 2007 8:11 pm
Very good image and effect.... Good job man!!!! :)
Post by suvakas » Thu Apr 12, 2007 9:10 pm
What's the adwantage of this method instead of using regular RGB lights and not SSS?
I can imagine, that it would be way faster when using rgb lights.
dougal2
Post by dougal2 » Thu Apr 12, 2007 9:18 pm
suvakas wrote:What's the adwantage of this method instead of using regular RGB lights and not SSS?
no real reason - other than it seems to look right.
