SSS material tests
You've changed some things...
1) old:<rgb>0 0.45 0.5</rgb> new: <rgb>0 4.5 5</rgb> <- ten times of first absorbtion...
2) old: <rgb>0.1 0.5 5</rgb> new <rgb>4 20 200</rgb>
40 times SSS... the rest looks quite simmilar, but also the material looks fine, I'd say! You'd need to use the ToP Mod Mesh, for testring the differences...
mrCarnivore
And then it will work?OnoSendai wrote:You don't need to go thru blender: just use the .ply file directly.
How can I position the object in the scene then?
I guess the problem with the colour really is finding the right combination and scale of the absorbtion and sss...
Still learning to handle sss. It's certainly not easy.
homer_simpson
I am new to Indigo and first: it's a fine rendering program. The idea of progressive rendering is nice.
I play a little bit with an SSS material rendered with OpenEXR lightning.
The result had a rendering time of 8h 25m on a AMD 3700 with 2 GB RAM.
Homer
Homer
- im1174349819.png (477.57 KiB) Viewed 3753 times
mrCarnivore
mrCarnivore
mrCarnivore
It is not? Nice to know. Thx. Never made extensive tests, I just assumed... (Note to myself: stop assuming and try it out more often)manitwo wrote:as far as i remeber my tests, exr lighting isnt slower than meshlight lighting
Oh! I thought you meant teenage ninja indigo tests.Kram1032 wrote:![]()
tint, I meant, but this doesn't exist, xD
It's Ink, sorry
Users browsing this forum: Google [Bot] and 71 guests
