42 The Strand
13 posts • Page 1 of 1
Deus
Post by Deus » Tue Feb 20, 2007 12:15 pm
Thats massive Radiance. Good work!
Post by OnoSendai » Tue Feb 20, 2007 9:09 pm
Very nice work Radiance!
A few crits:
* the building is a little sharper than the rest of the image.
Actually I think u need to use a better camera, cause it's a bit blurry and has quite a lot of chromatic aberration :)
* Trees would like nice with some alpha mapping, look pretty good as-is tho.
* The perspective is slightly disturbing... the backward tilt on the camera/building that is
Post by Kram1032 » Wed Feb 21, 2007 2:50 am
lol
The problem here is not your render, but the real image ^^
Looks nice!
Maybe, you could do it in 0.7 for some SSS in the palms leaves....
drBouvierLeduc
Post by drBouvierLeduc » Wed Feb 21, 2007 3:18 am
Hey, you probably already know, but in 2.43 blender release, there's a "2 point architect perspective" feature so you can get ride of the perspective problems. Didn't test it though.
btw nice render (need some textures maybe).
mrCarnivore
Post by mrCarnivore » Thu Mar 15, 2007 2:20 am
Looks nice.
But a little bit too clean. How about applying a little bit of bump or colour-texture to the building?
EDIT: Also if you want the perfect illusion you should blur the building a little bit since all the real elements are kind of blurry and instantly give away the rendered areas...
Post by Zom-B » Thu Mar 15, 2007 4:03 am
mrCarnivore wrote:EDIT: Also if you want the perfect illusion you should blur the building a little bit since all the real elements are kind of blurry and instantly give away the rendered areas...
... or just sharpen the original image :wink:
Post by Kram1032 » Thu Mar 15, 2007 4:31 am
...or add chromatic dispertion via Violet... (I think, I read somewhere that that's possible...)
mrCarnivore
Post by mrCarnivore » Thu Mar 15, 2007 4:38 am
Kram1032 wrote:which was mentionent above, already :D
Yeah, I know: I just saw the render and wrote a comment... (Bad me ;-) )
Will try to read the replies first, next time! :D
Post by Kram1032 » Thu Mar 15, 2007 4:40 am
Oh, lol^^ I edited and thought, I'll be fast enough.
mrCarnivore
Post by mrCarnivore » Thu Mar 15, 2007 4:54 am
Kram1032 wrote:Oh, lol^^ I edited and thought, I'll be fast enough.
Being a smartass never pays out! :D
Post by Kram1032 » Thu Mar 15, 2007 6:49 am
xD may be true....
F.ip2
Post by F.ip2 » Thu Mar 15, 2007 2:47 pm
drBouvierLeduc
how could u use that with indigo???
Artist : Designer : Educator
of Ferris State University
drBouvierLeduc
Post by drBouvierLeduc » Thu Mar 15, 2007 11:47 pm
F.ip2 wrote: how could u use that with indigo??? (shift in blender)
I couldn't ! I thought it could be exported to indigo, but I misunderstood everything, it doesn't work.
