Announcements, requests and support regarding Indigo for Revit
HBK
by HBK » Sun Jun 12, 2016 4:50 am
Hello,
I just installed Indigo for Revit and i'm trying to follow this tutorial to install and start using the renderer:
http://www.indigorenderer.com/documenta ... t-tutorial
The problem is that when i go to "edit render settings" and select the view that i want to render, then click ok, it ignores it and always starts rendering the {3D} default view. Anyone knows how can i solve this?
Thank you all!
gjengi
by gjengi » Mon Jun 13, 2016 11:37 pm
We're experiencing the same problem too. Is it best to roll back to an earlier version for the time being?
Thanks, Jen
Architect in training...
...almost done!
arc en ciel
by arc en ciel » Tue Jun 14, 2016 1:00 am
change rendering mode or click on "Enable OPENCL rendering"
reajust Render mode if you nedd it
start rendering, it will use an updated view
by Oscar J » Tue Jun 14, 2016 9:11 am
I think this is a general Indigo problem with how region rendering works currently. There has been some work done updating that afaik.
gjengi
by gjengi » Wed Jun 15, 2016 8:45 pm
Ah, ok. Is there any work around, as I can't seem to find the relevant settings that arc en ciel has suggested in the revit settings, and we'd like to use Indigo to generate some renders for an upcoming competition?
Thanks
...almost done!
arc en ciel
by arc en ciel » Thu Jun 16, 2016 12:27 am
hello
I was talking about settings in Indigo Renderer application.
I don't use Revit.
did you render inside Revit directly ? in this case i don't know...
arkitek
by arkitek » Wed Dec 07, 2016 10:17 am
i am having the same problem, it keeps defaulting to the standard 3d-view any fixes on this?
