Revit 2014 ???
Revit 2014 ???
Plugin for Revit 2014 ?
The version 3.4.16 NOT run...
Thanks !!!
Thanks !!!
Re: Revit 2014 ???
Hi init666,
we are currently working on a version for Revit 2014.
We made some big steps forward, so stay tuned
Re: Revit 2014 ???
Do you have ETA on this? We are evaluating our rendering pipeline in the office I work at, and I'd love to showcase indigo to the others.
Re: Revit 2014 ???
Actually we do have a new version of the Revit 2014 exporter available for beta testing, drop us an email at support@indigorenderer.com and we'll send it to youSilmä wrote:Do you have ETA on this? We are evaluating our rendering pipeline in the office I work at, and I'd love to showcase indigo to the others.
Re: Revit 2014 ???
Can't succesfully run Indigo in Revit 2014.
I cant see indigo plugin in Revit Interface, and also Revit posted, that it cant run app
How I installed plugin:
I use Windows 8 platform, so usually, as I Install any programm, i click right mouse button, and then choose "Run as administrator".
When I saw, that Revit cant run plugin, I copied all *.dll files to main Revit folder, and also in plugin folder, but nothing happend. Also I checked ...AppData\Roaming\Autodesk\Revit\Addins\2014 folder
Please, help me to add plugin to my Revit app. May be i doing something wrong, or nor fully.
Best regards. Mikhail/Russia/Novosibirsk
- fractal.design
Re: Revit 2014 ???
Hi, I believe I've the same feedback as Arkon:
Running:
Revit 2014 (Student Version)
Indigo_for_Revit_2014_v3.6.18 (via Yves Collé link in email)
Installed fine, but when I load Revit up after I get the error shown in image below:
Am I doing something wrong?
Running:
Re: Revit 2014 ???
Hi fractal.design,fractal.design wrote:Hi, I believe I've the same feedback as Arkon:
Running:
the DLLs in the beta aren't digitally signed. Windows 8 has this feature that unsigned DLLs will be blocked by default. You then get this error. This is already fixed for the final release.
To work around it, simply select all the DLLs in the Indigo for Revit directory, right click and select "Properties". Somewhere on the bottom of the dialog, there should be an "Unblock" button.
Sorry for the inconvenience.
Let us know how you like the beta for Revit 2014!
Best regards,
Yves
Re: Revit 2014 ???
I've got a error:
Scene parsing error: Model (UID 13) has a different number of materials than geometry material references.
num materials: 1, geometry num materials referenced: 0
Indigo version: Indigo Renderer v3.4.16, Windows 64-bit build.
No metadata.
Please contact support@indigorenderer.com if you have any questions.
No metadata.
Re: Revit 2014 ???
Hi kyjob,kyjob wrote:I've got a error:
No metadata.
could you try it with the new version here: http://www.indigorenderer.com/forum/vie ... 38&t=12694
Also, please install the Indigo version that is bundled with Indigo for Revit (Indigo Renderer 3.6.25).
If you are still having problems after that, it would help us a lot finding the problem if you could provide some Revit project file that shows the issue (you can email it to support@indigorenderer.com).
Kind regards,
Yves
