Atmospherics
- thesquirell
Atmospherics
How are we standing in terms of atmospherics, like aerial perspective or clouds? I couldn't find any working volumetric material in the library and the posts regarding this subject are somewhat old.
Re: Atmospherics
these projects are personal experimentations that have not yet led to such releases. I have though resumed my own works of clouds and am aiming at releasing one complex mat with interesting features soonish. Rendering clouds within a physical atmosphere seems to be tricky and certainly costly but doable.
Re: Atmospherics
If you have something to render, I'm happy to offer my 3 x 4770k systems to do the jobCTZn wrote:Rendering clouds within a physical atmosphere seems to be tricky and certainly costly but doable.
- thesquirell
Re: Atmospherics
CTZn, your work on this subject was amazing! Can't wait to see more more! I was just thinking how awesome would it be to have a full control over the atmosphere of our scenes within Indigo, or from host apps, something like http://support.nextlimit.com/display/mx ... olumetrics.
Re: Atmospherics
Zom-B: okay I have sent Ono a month ago or so a couple IGQ to render, I think I should crowd source the task instead since there is interest in the matter.
the squirrel: thanks, it's just noise with little modifications and rendered by Indigo
I think I'll rather post a simplified clouds material for starters ?
- thesquirell
Re: Atmospherics
"just noise with little modifications..." - you are a beast, man. For me, it is a rocket science!
That would be great, so we could start fiddling with the mat!
I would be the happiest man to see the creation of an atmosphere module for Indigo. And I think you "cloud" guys could get us there!
Re: Atmospherics
well thanks, I'm glad i can share interests !
so here's the current render, and yes it's the simplified version ! That should be out by the week.
édit: pic removed, see below.
Re: Atmospherics
awesome
- thesquirell
Re: Atmospherics
I just can't belive how good that loooks. I wanna know hoooow!
Re: Atmospherics
To be fair to whom deserves, Onto was the first to render clouds years ago; also for several releases now, rendering clouds is much faster than it was before.
Now I have a question about the Max extinction coefficient; it is quite low here.
Is it right to consider it a spatial resolution parameter ?
should shaders be designed for a value of 1.0 ?
what is Max extinction coef finally ?
Re: Atmospherics
once I was done I thought it was smart to change the Max extinction coeff to one from 0.025 and found myself with floating concrete bunkers then I los it for a moment
I'm creating a thread in the materials subforum around the release. I'm assuming the spatial resolution thingy.
