why the render is so noisy?
Come here for help & support.
4 posts • Page 1 of 1
tritube
Post by tritube » Sun Jan 16, 2011 12:36 am
i search a lot but didnt find a solution!
i use max 2009 and 2.4 maxigo
Re: why the render is so noisy?
Post by Headroom » Sun Jan 16, 2011 1:39 am
Indigo is an unbiased renderer that, in default settings, does not really stop rendering unless you explicitly tell it so.
It continues to refine the image by removing noise over time and it can take a while to clear up a render (hours rather than minutes). How quickly is determined by the computer hardware you use and of course there are a few things you can do when preparing the scene for Indigo. For example use Exit Portals when lighting an interior scene through a window.
tritube
Post by tritube » Sun Jan 16, 2011 1:56 am
hey Headroom thanks for your comment.
i need to know how to set up light on the scene
i only now understand that i need to create plane and apply 'Indigo Emitter' on it
but i dont know what to define on the emitter settings
there are no tutorials what should i do ? :(
Post by Zom-B » Sun Jan 16, 2011 3:54 am
Hey tritube,
the maxigo manual may be a good start: http://www.indigorenderer.com/3dsmax :roll:
For white walls etc. never use pure 255 RGB white since it is physically a full reflecting material that doesn't exist like this in nature. So you end up with noisy images like the one of yours!
set a RGB of Max 205 and tonemap it to a pure pleasing white :)
As Headroom suggested the noise is clearing over time, and your CPU specs + time you rendered are the interesting informations here ;)
