how to make auto close indigo renderer window ?
Come here for help & support.
4 posts • Page 1 of 1
hcpiter
Post by hcpiter » Fri Aug 27, 2010 8:06 am
Hello again today is day of question about indigo/maxigo ;)
so I try setup animation, all I have done but is one problem, why when I render animation I got setup path for output image, time output but when start and one frame is done Indigo wait and I must turn off window with render because when I turn off is started render 2nd frame and again when finish 2nd I must turn off for 3rd frame. All is good but where I can setup automatically turn off indigo render window ? Or maybe my setups are wrong ?
Re: how to make auto close indigo renderer window ?
Post by suvakas » Fri Aug 27, 2010 8:27 am
Go to your Indigo installation folder and edit your inifile.xml
Add the following line between <renderer_settings> tags:
<renderer_settings>
<close_gui_on_halt>true</close_gui_on_halt>
</renderer_settings>
This will be included to next Maxigo version, but currently editing ini file is the only option.
hcpiter
Post by hcpiter » Fri Aug 27, 2010 8:43 am
hehehe suvakas you are so fast in answers :D Thanks !
Post by Zom-B » Fri Aug 27, 2010 12:46 pm
a easy workarround would be rendering with indigo_console should be even rendering a tiny little faster ;-)
