Caustics and fog dont render on reflection and refraction.
Come here for help & support.
ior
Re: Caustics and fog dont render on reflection and refractio
Post by ior » Fri Sep 10, 2010 3:50 pm
Is this infinitely small intersection points and infinitely thin ray paths can be stored on disk. updating at a click of a button? No mater how time it takes. No more than we take on render!
Post by lycium » Sun Sep 12, 2010 6:41 am
the method we're working on should do a great job :)
Post by pixie » Mon Sep 13, 2010 8:53 am
lycium wrote:the method we're working on should do a great job :)
And once GCC gets used we the windows users will get a major speed boost! 8)
Updated: bust->boost, many thanks to Borgleader for having noticed it, we want speed to go free! ;)
Post by Borgleader » Mon Sep 13, 2010 8:59 am
And once GCC gets used we the windows users will get a major speed bust! 8)
bust --> boost :wink:
But yes, major speed increase is going to be very welcome!
Post by StompinTom » Mon Sep 13, 2010 10:44 am
Hungry for speed here! Can't wait to play with this new toy!
ior
Post by ior » Mon Oct 04, 2010 7:19 am
I see that developers moved a step towards the possibility off rendering refraction caustic effects by using Glass Accel.
Right now, in version 2.6.1, there is still a problem with multiple refraction objects (glass windows or whatever glass object), the second object that refract the caustics is still a little bit darker than the first and subsequently the rest of the objects are even darker.
Note that you can only use Glass Accel with sun and no exit portals.
Will this be available for other emitters as well?
I think the aim is to create a reflection acceleration method also. When can we see this implemented?
Kristof
Post by Kristof » Mon Oct 04, 2010 10:39 am
ior wrote:I see that developers moved a step towards the possibility off rendering refraction caustic effects by using Glass Accel.
I have recently finished a test using only mesh emitters where glass acceleration dramatically improved the results, you can refer to this link to see the test.
Kristof
Post by Kristof » Mon Oct 04, 2010 1:20 pm
OK here is my reflected caustics test, 30 minutes with a laptop.
I am also making use of glass acceleration. I have yet to run any comparisons with and without as of yet.
30min 1.6Ghz Dual Core
ior
Post by ior » Tue Oct 05, 2010 9:22 am
With glass acceleration Indigo really rocks! :D
Can't wait to see it applied to other emission objects.
Here are some examples:
with glass accel
without glass accel
with glass accel and mirror
In the last image see the perfect caustics of the pot in the mirror!
I modeled the room opening badly, that's why on the room opening, the bottom is illuminated by the sun, on the side there are reflections of the right side glasses.
Kristof
Post by Kristof » Tue Oct 05, 2010 12:01 pm
ior wrote:With glass acceleration Indigo really rocks! :D
Once more, glass acceleration works with mesh emitters and other emission objects as well as with the sun.
Also here is the same test without glass acceleration, this time only 14min though.
14min, No Glass Accel
ior
Post by ior » Wed Oct 06, 2010 6:09 am
Kristof wrote: Once more, glass acceleration works with mesh emitters and other emission objects as well as with the sun.
It does, didn't realize that because the tests I've done, were with small light sources.
Glass acceleration of mesh emitters seems to work better on refraction of caustics, small light sources still produce fireflies difficult to converge.
Why the floor is darker in the mirror side of your image? It is because the caustics are not being reflected or your mirror isn't near 100% reflective?
When you use the sun you cannot use outside exit portals for glass accel to work.
Volumetric fog is still not reflected or refracted with glass acceleration.
ior
Post by ior » Sun Oct 10, 2010 5:36 am
Here is an example of fireflies difficult to converge with glass acceleration and a small emitter.
small emitter fireflies
there is a sheet of glass in front of the camera with the edge ending in the middle of the pot caustics.
The fireflies will never converge in an acceptable time (24h).
Kristof
Post by Kristof » Mon Oct 11, 2010 10:23 am
Hi ior,
Are you using MLT? It is near impossible to work with caustics without it.
ior
Post by ior » Tue Oct 12, 2010 3:30 am
Kristof wrote: Are you using MLT? It is near impossible to work with caustics without it.
Hi.
I didn't try MTL, thanks for reminding me, maybe MTL also got improved with glass accel, I'll make some tests.
Post by Zom-B » Tue Oct 12, 2010 4:34 am
ior wrote:
Kristof wrote:...maybe MTL also got improved with glass accel...
MLT owns every scene that uses reflections, refraction & Co!!!
Also Try MLT vs MLT+BiDir!
With BiDir the Samples/s should be lower, but their "quality" is better, so you maybe end up with a better result.
Depends from scene to scene...
