Issue with linux version
Come here for help & support.
5 posts • Page 1 of 1
galinette
Post by galinette » Tue Jul 20, 2010 8:50 pm
Hello all,
I just tried the linux version for the first time.
I have the following issue : it complains not finding 'nkdata\Al.nk'. The file is there inside indigo dir, and the lettercase is OK. What's the issue?
I have also the following minor problem : I need to start the indigo binary from the indigo dir. I cannot do "~user\indigo_dir\indigo", otherwise it does not find its data files (such as infile.xml).
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
galinette
Re: Issue with linux version
Post by galinette » Tue Jul 20, 2010 8:54 pm
Ouch, it comes from the backslash which is not unix-friendly. This means that many database materials must be corrected for working under linux (both lettercase and backslashes are not ok). This is not convenient!
Etienne
Post by OnoSendai » Tue Jul 20, 2010 9:42 pm
All nk references should be written with the correct case and with forwards slash! Indigo should handle incorrect paths in this case, though.
galinette
Post by galinette » Tue Jul 20, 2010 10:21 pm
For instance, the "Brushed Aluminium" material from the database is not linux-compatible.
Some questions:
- Could the material db autocorrect the slashes from the uploaded materials?
- Does the material editor in windows always write correct slashes and lettercases?
- Does all exporters take care of this? I guess not. This may be an issue for network rendering on linux slaves, as they will not find the nkdatas
Etienne
Post by OnoSendai » Tue Jul 20, 2010 10:31 pm
Hi Etienne,
The easiest solution is for Indigo to handle the incorrect slashes and convert them, and is something I've been meaning to do for a while.
