Why my render image is all coverd with black?!
Come here for help & support.
6 posts • Page 1 of 1
anesthetized
Post by anesthetized » Sat Apr 03, 2010 8:52 am
Hi!
I created my first serious model in Sketch Up (I study landscape architecture) and i wanted to to render it with indigo. When i click 'render; in plugins menu rendering proces starts, but all image is coverd in black. No metter how long do i render it it is allways black? What's going on? When i try with another models every thing in OK.
BTW, how long should i render an image? It never stopes...
I use 2.2.12 trial version.
Greetings!
Meelis
Re: Why my render image is all coverd with black?!
Post by Meelis » Sun Apr 04, 2010 7:41 pm
Your normals should face out.
Do u have glass objects (with specular material) intersecting? If soo then intersecting objects should have different % (default is 10 for all, soo u set some 9 or 8, 7, 6, 5).
Do u have sun & sky, emitters, hdr map (some light source)?
Exit portals facing inside rome and camera beeing outside house will result black render.
Post by Pibuz » Tue Apr 06, 2010 1:26 am
anesthetized, hi and welcome.
A screen of your problem would surely help.
For me it is a matter of exposure: try increasing the ISO alue and see what happens!
anesthetized
Post by anesthetized » Fri Apr 09, 2010 3:47 am
Yes! It was the ISO value.. Thank You so much! I rased it to 1100 and that's the results... (rendering time was abaut 18 hours) still have more questions:
- what's (more or less) the proper value of ISO for the pictures like I made?
- how to change the day light like from noon to dusk?
and fountain of my designe- i'm proud of it :)
buss stop second view- now the glass is transparent
buss stop view. I know that the glass is too reflective, but noticed that too late :D
Post by Pibuz » Sun Apr 11, 2010 3:53 am
ISO value depends on f-stop number and shutter speed. Optical basis.
Here are some empiric parameters you can start to play with:
f/stop: f/11
shutter speed: input 100 (which means 1/100 seconds)
ISO: 400
These values are enough for exteriors, NOT valid for interiors.
Using SkIndigo, you change the light colour and general mood of you image simply varying the SketchUp sun's position.
Post by CTZn » Thu Apr 15, 2010 11:02 am
More informations on setting ISO (Wikipedia): Sunny 16 rule
