License Verification Failure
Come here for help & support.
4 posts • Page 1 of 1
iErik
Post by iErik » Tue Aug 30, 2022 3:52 pm
I have an Indigo 4 license that I have had for some time, but recently I am running into an issue where my license stops being verified after every time I shut down my computer and log back in. When I check the licensing menu the hardware key looks the same and the license key is still entered, but when I click "verify license key" I just get a warning that says "Sorry, verification of your license key failed. (Hash does not match license details and hardware ID). I have to request a license reset every time and then it works, until I shut down my pc again and then it starts over. I browsed the forums for similar issues but couldn't find anything. Any advice would be appreciated.
Re: License Verification Failure
Post by pixie » Tue Aug 30, 2022 10:48 pm
try to check if there's anything in the system messing with mac address of network board
iErik
Post by iErik » Sun Sep 04, 2022 6:36 am
Thank you, this was the problem. For some reason Indigo uses the MAC address from my wifi hardware even though it's disabled and I connect through an ethernet cable. "Random hardware address" was enabled for the wifi hardware which was resetting the MAC address every time I restarted, so once I disabled that I no longer have this issue. Thanks again!
Post by pixie » Mon Sep 05, 2022 1:15 am
you're welcome :)
