GPU doesn't use MLT so it won't take thees values into consideration, I guess...arc en ciel wrote:these options are :Zom-B wrote: Last idea is to give MLT another try raising the XYZ (forgot Name) value with default of 0.25 up to 0.85 vor higher!
With that you lose the cloudy Boise MLT generates and geht More PT like Boise Ostern, but without any Boxnoise at all.
The overall uniform noise should then be killed easy with neatvide.
Since I'm in vacation, I cant give ya the proper namens for the both options above...
- Large mutation Probe
- Max change
in my little experience, I put LMB to 0.51 - 0.7 and max change to 0.06-0.095
it's faster, but up these values the noise are more thick, bigger
maybe more easy for denoising in postpro ? I didn't try
here two images examples i ran in july, watch the name of the files for specifications, the big change is about large mutation probe from 0.78 to 1.78
the speed is multiply by 2, but the noise(s size too, the rendering's time does not change
Help with difficult indoor lighting
- pixie
Re: Help with difficult indoor lighting
Yes, I was refering to LMP!
You should test a inferior and not such a low bounce Studio setup
Also LMP max is 1.0 and same as the other feature, they are MLT only parameters...
MLT is generally a bad idea for videos, the low frequency noise make it flicker a lot.
For the elevator glass issue, one solution would be increasing the glass reflectivity (refractive index) but this changes the final result and you may not want it. The problem is transparency.
Eclat-Digital Research
http://www.eclat-digital.com
Subliminal messages to the devs : there is often a problem with noisy glass when the camera side is well lit (such as exterior, or in this case), and the back side is more in the shadow (such as interior). The importance sampling, I suppose, will highly favor transmission, whereas the contribution of reflection is in fine the largest. Having an option to sample with a probability of 0.5 gives a much better result in this case.
Using a high LMP value this low frequency noise gets way less!! Give it a trygalinette wrote:MLT is generally a bad idea for videos, the low frequency noise make it flicker a lot.
Yes, but I feel you also loose the efficiency of MLT. Is MLT with LMP=1 really more efficient than non-MLT?Zom-B wrote:Using a high LMP value this low frequency noise gets way less!! Give it a trygalinette wrote:MLT is generally a bad idea for videos, the low frequency noise make it flicker a lot.
The only advantage is that it doesn't have box noise.galinette wrote:Yes, but I feel you also loose the efficiency of MLT. Is MLT with LMP=1 really more efficient than non-MLT?Zom-B wrote:Using a high LMP value this low frequency noise gets way less!! Give it a trygalinette wrote:MLT is generally a bad idea for videos, the low frequency noise make it flicker a lot.
with LMP=1 all benefits of MLT are afaik lost, therefore the sweetspot for animations needs to be found, 0,85 has been find for my last animation...galinette wrote:Yes, but I feel you also loose the efficiency of MLT. Is MLT with LMP=1 really more efficient than non-MLT?
The big benefit is uniform noise and no boxnoise, both needed to let a temporal denoiser work efficiently, for other scenarios this approach might be not usable.
Congrats on the great results zeit.
- zeitmeister
Thank you very much!!
- Originalplan®
Congrats! Supercool project and final product!
And i'm not even into cars...so.
- zeitmeister
Thanks to your help guys... great forum, great people!
- Polinalkrimizei
Pure awesomeness!
Really adds something special to the frontpage.
Are you the only Indigo ambassador at your company?
Fantastic work.
Fantastic work.
