Noise issue.
Come here for help & support.
11 posts • Page 1 of 1
ryanee
Noise issue.
Post by ryanee » Sat May 28, 2016 2:02 am
hi,
I have had this image rendered for the past 17 hours yet it's still showing lots of noises. Any idea/guidance how should i tweak this?
Attached is the screenshot.
Re: Noise issue.
Post by Oscar J » Sat May 28, 2016 2:04 am
Info on scene setup, render settings, hardware etc. would help a lot. :)
Re: Noise issue.
Post by Zom-B » Sat May 28, 2016 4:13 am
Do you render in MLT mode?
Try BiDir PathTracing instead, since MLT is knowen to keep noise over long render time...
And yes, without the info Oscar requested, your ask for help is not to easy to fullfill :roll:
Please show us the full renderer...
ryanee
Re: Noise issue.
Post by ryanee » Sat May 28, 2016 2:38 pm
first of all thanks for the reply.
I attached the screenshots of the render settings. Since I am new to this so I have provided all I can find, shall I miss anything pls let me know.
ryanee
Re: Noise issue.
Post by ryanee » Sat May 28, 2016 2:41 pm
It's a interior screen and I am using iMac, detail as attached. I guess hardware ain't an issue?
Yes, it was rendered with Bidirectional with MLT mode bcos I remember reading somewhere that this mode is the best for interior rendering...
Re: Noise issue.
Post by Zom-B » Sun May 29, 2016 2:12 am
The full image would still be very helpfull, by that we could sugest features like ArchGlass and ExitPortal that could help a lot (!!) speeding up rendering.... but we have no idea how lighting is setup in your case...
As already sugested: use BiDir PathTracing for rendering!
MLT is good for special scenes with complicated light situations many caustics etc. BiDir PT is best choice for 90% of the scenes, and also for Interiors.
Your hardware is quite medicore, since your CPU does not have any Hyper Threading, so only 4x3,2Ghz.
Indigo does scale very nicely with HT on Intel CPU's, so your CPU is maybe half as fast as a i7 4770.
Re: Noise issue.
Post by Oscar J » Sun May 29, 2016 2:35 am
Bubs, one of the best arch viz people on here, does amazing interiors and exteriors with an i5 processor. Pibuz, another power user, renders on a Core 2 Quad. With the right knowledge and some patience, your hardware shouldn't be a problem for stills. :)
Arch glass and BiDir should be a good start for optimisation, then you can try exit portals as well, especially if your windows are small.
Keep it up! :)
ryanee
Re: Noise issue.
Post by ryanee » Sun May 29, 2016 3:38 am
Zom-B wrote:The full image would still be very helpfull, by that we could sugest features like ArchGlass and ExitPortal that could help a lot (!!) speeding up rendering.... but we have no idea how lighting is setup in your case...
Noted. Attached herewith the image.
Re: Noise issue.
Post by Oscar J » Sun May 29, 2016 3:52 am
Yeah, that looks like a scene that would do fine with BiDir and arch glass + exit portals at the door.
contegufo
Re: Noise issue.
Post by contegufo » Sun May 29, 2016 6:11 am
Hi
The threads should be 4, however, the choice is automatic and should see all 4 as it happens to me.
ryanee
Re: Noise issue.
Post by ryanee » Tue May 31, 2016 9:27 pm
Oscar J, Zom-B and contegufo,
thanks for all your feedback and advise. I took into consideration all of your advises and it is now working perfectly fine.
Cheers.
