Help needed : Indigo not responding (Skindigo RT)
Come here for help & support.
9 posts • Page 1 of 1
Alejandro_66
Post by Alejandro_66 » Tue Mar 17, 2015 6:04 am
Hello everyone,
I have a problem with Indigo freezing an "not responding" message each and every time i try to, either save image or IGI file... Render for 10 minutes or 10 hours with same result... Very frustrating at this point...
Any help welcomed. Thank you.
Alejandro
Re: Help needed : Indigo not responding (Skindigo RT)
Post by Oscar J » Tue Mar 17, 2015 6:15 am
What resolution are you rendering in?
Alejandro_66
Post by Alejandro_66 » Tue Mar 17, 2015 6:33 am
Oscar J wrote:What resolution are you rendering in?
Oscar i was rendering in 2800x2000.
Post by Zom-B » Wed Mar 18, 2015 7:33 pm
Check RAM usage during the rendering/saving.
If you start a rendering, in the displayed log there is a line named "Master buffer size:" how big is that for your scene?
And last but not least: has the HDD you save your stuff on enough free space??! ;)
Alejandro_66
Post by Alejandro_66 » Thu Mar 19, 2015 12:53 am
Zom-B wrote:Check RAM usage during the rendering/saving.
Hello Zom-B,
Yes I have sufficient space. I start the render and everything is fine up until I try to save image...
Left a render to work through the night, came back this morning and still same problem...
Here's a screen capture with Render log.
Thank you very much for taking the time to help me solve this problem.
Kind regards,
Alejandro
Post by Oscar J » Thu Mar 19, 2015 12:59 am
Have you tried reinstalling Indigo?
Alejandro_66
Post by Alejandro_66 » Thu Mar 19, 2015 1:46 am
Oscar J wrote:Have you tried reinstalling Indigo?
I think i have no choice at this point. I will let you know if it solves the problem.
Thank you.
Alejandro
Post by Zom-B » Fri Mar 20, 2015 7:51 am
Don't use GPU rendering, that should fix your issue!
Alejandro_66
Post by Alejandro_66 » Sat Mar 21, 2015 5:45 am
Zom-B wrote:Don't use GPU rendering, that should fix your issue!
Hello Zom-B, So far that seems to work! Thank you!
