Come here for help & support.
faffo
by faffo » Thu Dec 22, 2011 10:45 pm
Hi guys,
I've been trying to find the issue without result...This is the message:
Error: Scene parsing error: Syntax error while parsing real 3-vector from 'nan nan nan'
Skindigo 3.0.14 trial on Imac i5 27"
Ideas?
Cheers
snorky
by snorky » Thu Dec 22, 2011 11:05 pm
faffo wrote:Hi guys,
Ideas?
Cheers
purge scene...
do you use external mesh?
faffo
by faffo » Thu Dec 22, 2011 11:52 pm
[/quote]
purge scene...
do you use external mesh?[/quote]
The mesh is imported but i've also other imported meshes of same source in other files and is working correctly
(but this doesn't mean that in THIS mesh something is wrong...)
purge dosn't resolve.
faffo
by faffo » Fri Dec 23, 2011 1:16 am
Zom-B:
installed skindigo 3.0.15 and now i get this different message:
Error while building scene: No such material 'Default'
I tried with other scenes (until now working fine) and i get the same message, so i must revert to the skindigo 3.0.14 back
Thank you for support!
by Zom-B » Fri Dec 23, 2011 1:21 am
Maybe try Skindigo version 3.0.22 instead (link in my last post!)
If something isn't working probably trying the latest (beta) versions can be a good way of "fixing" issues... sometime
faffo
by faffo » Fri Dec 23, 2011 1:46 am
Yes i see it but for Mac is coming soon...not yet available
thank you aniway
by Whaat » Sat Dec 24, 2011 5:13 pm
Go to Model Info->Statistics->Fix problems and try exporting again using Skindigo 3.0.14.
Sorry that 3.2.2 is not out yet for Mac, it fixes the no such material "Default" errors. I will release an update soon for both PC and Mac
faffo
by faffo » Mon Dec 26, 2011 6:47 am
statistics / fix problems -> no problems found... exported with 3.0.14 and the error is still there.
cheers
