Help!! What is this mean!! Please
Come here for help & support.
3 posts • Page 1 of 1
PowerMax
Post by PowerMax » Mon Oct 03, 2011 2:33 am
Error while building scene: ModelLoadingStreamHandlerExcep: Triangle material_index is out of bounds. (material index=4)
What is that mean..... Is it means something is out of the limit of quantity? I should reduce some stuff? Or something is out of certain thing? I should find it and cut that off?
Re: Help!! What is this mean!! Please
Post by Headroom » Mon Oct 03, 2011 11:52 am
It would probably help to know with what modeling application you work.
Post by CTZn » Mon Oct 03, 2011 1:40 pm
Exceptions are always caused by an exporter bug, that's why it is best to report such errors into the plugin thread. They should not happen.
An usefull bug report would include a scene file reduced to the elements causing the error, or would come with a reproductible manipulation sequence causing the error. At a minimum, with a description of the scene, thanks.
The error means that the scene definition is pointing Indigo to an element that doesn't exist, probably an additional UV set.
Users browsing this forum: No registered users and 84 guests
